Group Data Table messages using a field Graylog
Graylog version: 3.3.15
OS Version: Linux 5.11.0 on AWS VM
Hi everybody,
I have a Data Table connected to a stream where I receive the connections to the services. A field in the entering messages has a URL with the format domain.com / service /client_id, and I visualized them alongside other insights, resulting in something like:
  • domain/service1/client1
  • domain/service1/client2
  • domain/service1/client3
  • domain/service1/client4
The problem comes when I try to group them in a single field related to the service, like:
  • domain/service1/Insight1 Insight2
  • domain/service2/Insight1 Insight2
Is there a way to achieve this? I have been searching for ages on my own and nothing has helped me out so far, I really appreciate any ideas you might have on this.
Thanks!
Hello && Welcome.
I might be able to help.
Within each message does it contain all of these at once?
If not, you could create a field/s called "client’ then group those fields through a pipeline.
Could you explain in greater detail what your trying to achieve?
