i’m using
OS RHEL7,Graylog3,elasticsearch 5.6.16,filebeat 5.6.16 and all of them configured successfully,but there is no message recieved in graylog3
Note: Filebeat output all messages to elasticsearch ,also i created input for filebeat in graylog3 and it is running with no messages recieved
Graylog3 log:
2019-06-17T23:23:14.895+02:00 INFO [Periodicals] Starting [org.graylog.plugins.enterprise.search.db.SearchesCleanUpJob] periodical in [0s], polling every [28800s].
2019-06-17T23:23:15.179+02:00 INFO [JerseyService] Enabling CORS for HTTP endpoint
2019-06-17T23:23:30.795+02:00 WARN [AuditEventModelProcessor] REST endpoint does not use a registered audit type: DELETE api/plugins/org.graylog.plugins.enterprise/views/{id}/share (type: “views:view_sharing:delete”)
2019-06-17T23:23:30.796+02:00 WARN [AuditEventModelProcessor] REST endpoint does not use a registered audit type: POST api/plugins/org.graylog.plugins.enterprise/views/{id}/share (type: “views:view_sharing:create”)
2019-06-17T23:23:34.549+02:00 INFO [NetworkListener] Started listener bound to [10.208.221.18:9000]
2019-06-17T23:23:34.551+02:00 INFO [HttpServer] [HttpServer] Started.
2019-06-17T23:23:34.551+02:00 INFO [JerseyService] Started REST API at <10.208.221.18:9000>
2019-06-17T23:23:34.551+02:00 INFO [ServiceManagerListener] Services are healthy
2019-06-17T23:23:34.552+02:00 INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2019-06-17T23:23:34.552+02:00 INFO [ServerBootstrap] Services started, startup times in ms: {InputSetupService [RUNNING]=5, OutputSetupService [RUNNING]=6, BufferSynchronizerService [RUNNING]=6, GracefulShutdownService [RUNNING]=7, KafkaJournal [RUNNING]=8, EtagService [RUNNING]=28, JournalReader [RUNNING]=29, ConfigurationEtagService [RUNNING]=30, LookupTableService [RUNNING]=32, StreamCacheService [RUNNING]=65, PeriodicalsService [RUNNING]=110, JerseyService [RUNNING]=19753}
2019-06-17T23:23:34.558+02:00 INFO [ServerBootstrap] Graylog server up and running.
2019-06-17T23:23:34.559+02:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2019-06-17T23:23:34.570+02:00 INFO [InputStateListener] Input [Beats/5d07fcf4d4e15073720cd665] is now STARTING
2019-06-17T23:23:34.690+02:00 INFO [InputStateListener] Input [Beats/5d07fcf4d4e15073720cd665] is now RUNNING
2019-06-17T23:23:34.698+02:00 WARN [AbstractTcpTransport] receiveBufferSize (SO_RCVBUF) for input Beats2Input{title=filebeat, type=org.graylog.plugins.beats.Beats2Input, nodeId=a254b10c-df99-4dae-be94-1845b87e387f} (channel [id: 0xaec6260a, L:/10.208.221.18:5044]) should be 1048576 but is 2097152.
2019-06-18T00:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T01:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T02:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T03:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T04:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T05:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T06:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T07:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T08:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2019-06-18T09:23:14.894+02:00 ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
Elasticsearch log :
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [aggs-matrix-stats]
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [ingest-common]
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [lang-expression]
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [lang-groovy]
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [lang-mustache]
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [lang-painless]
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [parent-join]
[2019-06-17T22:09:50,951][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [percolator]
[2019-06-17T22:09:50,952][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [reindex]
[2019-06-17T22:09:50,952][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [transport-netty3]
[2019-06-17T22:09:50,952][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] loaded module [transport-netty4]
[2019-06-17T22:09:50,952][INFO ][o.e.p.PluginsService ] [Sf1Zaf0] no plugins loaded
[2019-06-17T22:09:52,302][INFO ][o.e.d.DiscoveryModule ] [Sf1Zaf0] using discovery type [zen]
[2019-06-17T22:09:52,736][INFO ][o.e.n.Node ] initialized
[2019-06-17T22:09:52,736][INFO ][o.e.n.Node ] [Sf1Zaf0] starting …
[2019-06-17T22:09:52,895][INFO ][o.e.t.TransportService ] [Sf1Zaf0] publish_address {10.208.221.18:9300}, bound_addresses {10.208.221.18:9300}
[2019-06-17T22:09:52,904][INFO ][o.e.b.BootstrapChecks ] [Sf1Zaf0] bound or publishing to a non-loopback address, enforcing bootstrap checks
[2019-06-17T22:09:55,950][INFO ][o.e.c.s.ClusterService ] [Sf1Zaf0] new_master {Sf1Zaf0}{Sf1Zaf0RTPS7BEb9zYRdkw}{XYabQ0qFTsGq0XUcwKEQ6g}{10.208.221.18}{10.208.221.18:9300}, reason: zen-disco-elected-as-master ([0] nodes joined)
[2019-06-17T22:09:55,964][INFO ][o.e.h.n.Netty4HttpServerTransport] [Sf1Zaf0] publish_address {10.208.221.18:9200}, bound_addresses {10.208.221.18:9200}
[2019-06-17T22:09:55,964][INFO ][o.e.n.Node ] [Sf1Zaf0] started
[2019-06-17T22:09:55,972][INFO ][o.e.g.GatewayService ] [Sf1Zaf0] recovered [0] indices into cluster_state
[2019-06-17T22:37:34,426][INFO ][o.e.c.m.MetaDataCreateIndexService] [Sf1Zaf0] [filebeat-2019.06.17] creating index, cause [auto(bulk api)], templates [filebeat], shards [5]/[1], mappings [default]
[2019-06-17T22:37:34,674][INFO ][o.e.c.m.MetaDataMappingService] [Sf1Zaf0] [filebeat-2019.06.17/YFG88m60QvmgWCnCgNUm9Q] create_mapping [doc]
[2019-06-17T22:38:45,609][INFO ][o.e.c.m.MetaDataCreateIndexService] [Sf1Zaf0] [graylog_0] creating index, cause [api], templates [graylog-internal], shards [4]/[0], mappings [message]
[2019-06-17T22:38:45,793][INFO ][o.e.c.m.MetaDataCreateIndexService] [Sf1Zaf0] [filebeat_0] creating index, cause [api], templates [filebeat-template], shards [4]/[0], mappings [message]
filebeat log:
2019-06-18T11:12:50+03:00 INFO Harvester started for file: /var/log/Process order sample - Copy.log
2019-06-18T11:12:59+03:00 INFO Non-zero metrics in the last 30s: filebeat.harvester.open_files=1 filebeat.harvester.running=1 filebeat.harvester.started=1 libbeat.es.call_count.PublishEvents=1 libbeat.es.publish.read_bytes=444 libbeat.es.publish.write_bytes=14475 libbeat.es.published_and_acked_events=36 libbeat.publisher.published_events=36 publish.events=37 registrar.states.current=1 registrar.states.update=37 registrar.writes=1
2019-06-18T11:13:29+03:00 INFO No non-zero metrics in the last 30s
