Graylog unable to receive message from logstash
Hi Graylog,
Currently i am setting up a logstash-gelf plugin to call a JDBC query and push the logs to Graylog.
Below is my logstash.conf.
input {
  jdbc {
    jdbc_driver_library => "/logstash-6.3.0/lib/sqljdbc42.jar"
    jdbc_driver_class => "com.microsoft.sqlserver.jdbc.SQLServerDriver"
    jdbc_connection_string => "jdbc:sqlserver://XXX:XXX;databaseName=XXX"
    jdbc_user => "XXX"
    jdbc_password => "XXX"
    schedule => "* * * * *"
    statement => "select xxx from XXX"
output {
  gelf {
  host => "graylog_ip_address"
  port => 12201
  short_message => "Testing gelf output"
  stdout { codec => rubydebug }
Below is my GELF HTTP configurations.
GELF HTTP : Running
bind_address: graylog_ip_address
decompress_size_limit: 8388608
enable_cors: true
idle_writer_timeout: 60
max_chunk_size: 65536
override_source: <empty>
port: 12201
recv_buffer_size: 1048576
tcp_keepalive: false
tls_cert_file: <empty>
tls_client_auth: disabled
tls_client_auth_cert_file: <empty>
tls_enable: false
tls_key_file: <empty>
tls_key_password: ********
Once i started the logstash, i received this message.
[2018-07-16T10:50:01,468][WARN ][logstash.outputs.gelf    ] Trouble sending GELF event {:gelf_event=>{"short_message"=>nil, "full_message"=>"%{message}", "host"=>"%{host}", "_project_loc"=>#<BigDecimal:2332822,'0.2241E4',4(28)>, "level"=>6}, :event=>#<LogStash::Event:0x603e8073>, :error=>#<ArgumentError: short_message is missing. Options version, short_message and host must be set.>}
[2018-07-16T10:50:01,469][WARN ][logstash.outputs.gelf    ] Trouble sending GELF event {:gelf_event=>{"short_message"=>nil, "full_message"=>"%{message}", "host"=>"%{host}", "_project_loc"=>#<BigDecimal:15a1bebe,'0.62322E5',5(28)>, "level"=>6}, :event=>#<LogStash::Event:0xce2e8c3>, :error=>#<ArgumentError: short_message is missing. Options version, short_message and host must be set.>}
[2018-07-16T10:50:01,471][WARN ][logstash.outputs.gelf    ] Trouble sending GELF event {:gelf_event=>{"short_message"=>nil, "full_message"=>"%{message}", "host"=>"%{host}", "_project_loc"=>#<BigDecimal:5ee37d2a,'0.176975E6',6(28)>, "level"=>6}, :event=>#<LogStash::Event:0x50122e7e>, :error=>#<ArgumentError: short_message is missing. Options version, short_message and host must be set.>}
[2018-07-16T10:50:01,472][WARN ][logstash.outputs.gelf    ] Trouble sending GELF event {:gelf_event=>{"short_message"=>nil, "full_message"=>"%{message}", "host"=>"%{host}", "_project_loc"=>#<BigDecimal:2c43723a,'0.243315E6',6(28)>, "level"=>6}, :event=>#<LogStash::Event:0x6c4750fd>, :error=>#<ArgumentError: short_message is missing. Options version, short_message and host must be set.>}
[2018-07-16T10:50:01,473][WARN ][logstash.outputs.gelf    ] Trouble sending GELF event {:gelf_event=>{"short_message"=>nil, "full_message"=>"%{message}", "host"=>"%{host}", "_project_loc"=>#<BigDecimal:31d7ba12,'0.428476E6',6(28)>, "level"=>6}, :event=>#<LogStash::Event:0x3b7c3791>, :error=>#<ArgumentError: short_message is missing. Options version, short_message and host must be set.>}
[2018-07-16T10:50:01,474][WARN ][logstash.outputs.gelf    ] Trouble sending GELF event {:gelf_event=>{"short_message"=>nil, "full_message"=>"%{message}", "host"=>"%{host}", "_project_loc"=>#<BigDecimal:71c0c1be,'0.554283E6',6(28)>, "level"=>6}, :event=>#<LogStash::Event:0x5ba99de6>, :error=>#<ArgumentError: short_message is missing. Options version, short_message and host must be set.>}
Graylog did not receive any message from the UI side. Is my configurations wrong?
Graylog version : 2.4.5
Logstash : 6.3.0
Logstash GELF output plugin : logstash-output-gelf (3.1.7)
the logstash output gelf is not gelf http - https://www.elastic.co/guide/en/logstash/current/plugins-outputs-gelf.html
You should create a UDP Input on Graylog to receive the events.
Additionally to what @jan already wrote, you have to set the short_message field in Logstash.
Thank you Jan and jochen for replying. Yes, the correct input is GELF UDP.
Below is my logstash configurations that make it worked.
input {
  jdbc {
    jdbc_user => "XXX"
filter {
 mutate {
   add_field => { "message" => "Test server" }
   add_field => { "host" => "graylog_server" }
output {
  gelf {
  port => 12201
Below is my GELF UDP INPUT setting.
GELF UDP : running
bind_address: graylog_server
port: 12201
recv_buffer_size: 262144
Thank you.
