Graylog stream extractor
HI Guys,
I’m trying to add an extractor of a stream (msg=“Gateway Anti-Virus Alert: (Cloud Id: 75044252) Browsefox-6628766-0 (Adware) blocked.”) and i want to extract from the full message only Adware, Trojan, ransomware, etc)
I have tried many options but none of them is suitable.
Any idea how to extract only that specific word?
Laurentiu
  1. you can create extractors to inputs, you can’t do on a stream.
  2. Use regexp.
i already tried to create an extractor but maybe because of my lack of knowledge, it doesn’t work
msg=%{WORD:}
you can see many-many examples in the community.
Try to use this grok:
msg="%{GREEDYDATA:UNWANTED}: \(%{GREEDYDATA:UNWANTED}: %{BASE10NUM:UNWANTED}\) %{GREEDYDATA:UNWANTED} \(%{WORD:virus-type}\)
And read doc, to undestand:
https://docs.graylog.org/en/3.2/pages/extractors.html#using-grok-patterns-to-extract-data
i have create a grok pattern like adware|ransomware|trojan etc and than i have create extractor to full message with %{name _grock patter:action} and it worked.
thanks for your inputs
