Graylog stops processing messages
I’ve had some issues with Graylog in last couple of days. At some point it stops processing messages. New messages are being added to process buffer, so it fills up quickly, then the same with yournal.
Once I remove journal and restart Graylog, it works fine for a while.
Graylog 3.2.1
ES 6.5.4
Logstash GELF UPD input
Here are Graylog errors in logs that I found:
2020-02-12 08:52:10,144 ERROR: org.graylog2.shared.buffers.processors.DecodingProcessor - Error processing message RawMessage{id=f47a6af0-4d74-11ea-9f76-0242ac110006, journalOffset=117014, codec=gelf, payloadSize=507, timestamp=2020-02-12T08:52:10.143Z, remoteAddress=/<IP>:38753}
java.lang.IllegalArgumentException: GELF message <f47a6af0-4d74-11ea-9f76-0242ac110006> (received from < <IP>:38753>) has invalid "short_message":
        at org.graylog2.inputs.codecs.GelfCodec.validateGELFMessage(GelfCodec.java:255) ~[graylog.jar:?]
        at org.graylog2.inputs.codecs.GelfCodec.decode(GelfCodec.java:140) ~[graylog.jar:?]
        at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:150) ~[graylog.jar:?]
        at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:91) [graylog.jar:?]
        at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:90) [graylog.jar:?]
        at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:47) [graylog.jar:?]
        at java.lang.Thread.run(Thread.java:745) [?:1.8.0_66-internal]
2020-02-12 08:52:10,145 ERROR: org.graylog2.shared.buffers.processors.DecodingProcessor - Unable to decode raw message RawMessage{id=f47a6af1-4d74-11ea-9f76-0242ac110006, journalOffset=117015, codec=gelf, payloadSize=515, timestamp=2020-02-12T08:52:10.143Z, remoteAddress=/<IP>:38753} on input <5b90f0f54cedfd00145d2ebd>.
2020-02-24 10:07:20,308 ERROR: org.graylog2.shared.buffers.processors.DecodingProcessor - Error processing message RawMessage{id=71b35f00-56ed-11ea-af1d-0242ac110006, journalOffset=1620208, codec=gelf, payloadSize=5510, timestamp=2020-02-24T10:07:20.304Z, remoteAddress=/<IP>:34946}
com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'u was expecting ('true', 'false' or 'null')
{A��ew�wU��ZF2��sriF�|����i�梿>�ӷ>*�����7��>*�%rŒA2SkOW
������&}2kP܆�~g�+lC���jZ�+-�_I]�Qqu��u�<�pA�b�3ô��:x^�����44����Vf�n�M��l����3j���j)0�H���W�`����M=EP�8;�2`��v^����X���\�       ҹ�h+�$_���{Nx��~\B������-5(I6_%yͮ��A��J5?_I���gg���x��Ez�<Y|��v��R�8����3I��O��V鵧�UI'��?����C�4�▒▒ڜ��X���}s�>��n����x�w��
&JJ%���[`�$�1Y�,�A�d��1���8�<�MM
                                ʜ�h�~�q��Q$/�R��t�.�ەB���y��cYhX��%�!�+��`Hrɀ��\Iw��u!Η��1��AT���,�`E
t������${�x�0��B�L��"[truncated 4735 chars]; line: 1, column: 3]
        at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:1804) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:703) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._reportInvalidToken(ReaderBasedJsonParser.java:2853) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._handleOddValue(ReaderBasedJsonParser.java:1899) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:757) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper._readTreeAndClose(ObjectMapper.java:4043) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper.readTree(ObjectMapper.java:2552) ~[graylog.jar:?]
        at org.graylog2.inputs.codecs.GelfCodec.decode(GelfCodec.java:130) ~[graylog.jar:?]
xterm-256colorxterm-256color    at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:47) [graylog.jar:?]
xterm-256color  at com.codahale.metrics.InstrumentedThreadFactory$InstrumentedRunnable.run(InstrumentedThreadFactory.java:66) [graylog.jar:?]
2020-02-24 10:13:15,599 ERROR: org.glassfish.jersey.server.ServerRuntime$Responder - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: java.io.IOException: Connection closed
        at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[graylog.jar:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[graylog.jar:?]
        at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
        at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
        at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
        at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_66-internal]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_66-internal]
Caused by: java.io.IOException: Connection closed
        at org.glassfish.grizzly.asyncqueue.TaskQueue.onClose(TaskQueue.java:331) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.onClose(AbstractNIOAsyncQueueWriter.java:501) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.transport.TCPNIOTransport.closeConnection(TCPNIOTransport.java:402) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.NIOConnection.doClose(NIOConnection.java:647) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.NIOConnection$6.run(NIOConnection.java:613) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.DefaultSelectorHandler.execute(DefaultSelectorHandler.java:238) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.NIOConnection.terminate0(NIOConnection.java:607) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.transport.TCPNIOConnection.terminate0(TCPNIOConnection.java:291) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:136) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:106) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.processAsync(AbstractNIOAsyncQueueWriter.java:344) ~[graylog.jar:?]
        at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:108) ~[graylog.jar:?]
        at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:526) ~[graylog.jar:?]
        at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:112) ~[graylog.jar:?]
        at org.glassfish.grizzly.strategies.SameThreadIOStrategy.executeIoEvent(SameThreadIOStrategy.java:103) ~[graylog.jar:?]
        at org.glassfish.grizzly.strategies.AbstractIOStrategy.executeIoEvent(AbstractIOStrategy.java:89) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.SelectorRunner.iterateKeyEvents(SelectorRunner.java:415) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.SelectorRunner.iterateKeys(SelectorRunner.java:384) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.SelectorRunner.doSelect(SelectorRunner.java:348) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.SelectorRunner.run(SelectorRunner.java:279) ~[graylog.jar:?]
        at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:593) ~[graylog.jar:?]
        at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:573) ~[graylog.jar:?]
        ... 1 more
Caused by: java.io.IOException: Broken pipe
        at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:1.8.0_66-internal]
        at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:1.8.0_66-internal]
        at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:1.8.0_66-internal]
        at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:1.8.0_66-internal]
        at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:1.8.0_66-internal]
        at org.glassfish.grizzly.nio.transport.TCPNIOUtils.flushByteBuffer(TCPNIOUtils.java:149) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.transport.TCPNIOUtils.writeCompositeBuffer(TCPNIOUtils.java:86) ~[graylog.jar:?]
        at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:129) ~[graylog.jar:?]
        ... 1 more
2020-02-24 10:01:34,342 ERROR: org.graylog2.inputs.codecs.GelfChunkAggregator - Received duplicate chunk 86 for message 2b985c60d7f868ec from null
2020-02-24 10:01:34,343 ERROR: org.graylog2.inputs.codecs.GelfChunkAggregator - Received duplicate chunk 95 for message 2b985c60d7f868ec from null
2020-02-24 10:01:34,343 ERROR: org.graylog2.inputs.codecs.GelfChunkAggregator - Received duplicate chunk 98 for message 2b985c60d7f868ec from null
Can I get some help, please?
If any config needed, I’ll add it, just let know what.
Thanks,
Daniel
the errors are ingest errors - showing messages that do not follow the rules of GELF messages.
Your described problems let me more think that you had Elasticsearch problems or have performance issues in Elasticsearch.
You might want to read https://facinating.tech/2020/02/22/in-depth-guide-to-running-elasticsearch-in-production/ to understand this better.
