Graylog stop indexing event journal disk grow up
Hi there Graylog community
Like I says in the title I have an issue indexing event in Graylog. After few hours my craylog single node stop indexing event in the Elastisearch database.
Any idea that should help me ?
Issue overview
Output stay at “0” and my journal disk size grow up until 100%+ :
Graylog system version
Hostname:
graylog1
Node ID:
93578a01-da62-401c-8563-4147c029fe5e
Version:
3.3.2+ade4779, codename Sloth Rocket
JVM:
PID 16201, Oracle Corporation 1.8.0_252 on Linux 4.9.0-13-amd64
Time:
2020-07-29 11:50:25 +02:00
Elasticsearch Health
"cluster_name" : "graylog",
"status" : "green",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"active_primary_shards" : 836,
"active_shards" : 836,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 0,
"active_shards_percent_as_number" : 100.0
error I found
3 hours ago graylog_2784 4012f260-d16f-11ea-809e-005056a775aa {"type":"illegal_argument_exception","reason":"mapper [http_code] of different type, current_type [long], merged_type [keyword]"}
error log that I found from Elasticsearch :
[2020-07-29T11:58:24,543][INFO ][o.e.c.m.MetaDataMappingService] [graylog1-graylog] [graylog_2787/Tb9VBXgjSuCtg_rZWO_JVw] update_mapping [message]
[2020-07-29T11:58:24,561][INFO ][o.e.c.m.MetaDataMappingService] [graylog1-graylog] [graylog_2787/Tb9VBXgjSuCtg_rZWO_JVw] update_mapping [message]
[2020-07-29T11:58:24,584][INFO ][o.e.c.m.MetaDataMappingService] [graylog1-graylog] [graylog_2787/Tb9VBXgjSuCtg_rZWO_JVw] update_mapping [message]
[2020-07-29T11:58:24,611][INFO ][o.e.c.m.MetaDataMappingService] [graylog1-graylog] [graylog_2787/Tb9VBXgjSuCtg_rZWO_JVw] update_mapping [message]
[2020-07-29T11:58:24,654][INFO ][o.e.c.m.MetaDataMappingService] [graylog1-graylog] [graylog_2787/Tb9VBXgjSuCtg_rZWO_JVw] update_mapping [message]
[2020-07-29T11:58:24,669][DEBUG][o.e.a.a.i.m.p.TransportPutMappingAction] [graylog1-graylog] failed to put mappings on indices [[[graylog_2787/Tb9VBXgjSuCtg_rZWO_JVw]]], type [message]
java.lang.IllegalArgumentException: mapper [http_code] of different type, current_type [long], merged_type [keyword]
at org.elasticsearch.index.mapper.FieldMapper.doMerge(FieldMapper.java:354) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.NumberFieldMapper.doMerge(NumberFieldMapper.java:1093) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.FieldMapper.merge(FieldMapper.java:340) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.FieldMapper.merge(FieldMapper.java:52) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.ObjectMapper.doMerge(ObjectMapper.java:487) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.RootObjectMapper.doMerge(RootObjectMapper.java:278) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.ObjectMapper.merge(ObjectMapper.java:457) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.RootObjectMapper.merge(RootObjectMapper.java:273) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.Mapping.merge(Mapping.java:91) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.index.mapper.DocumentMapper.merge(DocumentMapper.java:339) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.metadata.MetaDataMappingService$PutMappingExecutor.applyRequest(MetaDataMappingService.java:273) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.metadata.MetaDataMappingService$PutMappingExecutor.execute(MetaDataMappingService.java:231) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.MasterService.executeTasks(MasterService.java:643) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.MasterService.calculateTaskOutputs(MasterService.java:270) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.MasterService.runTasks(MasterService.java:200) [elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.MasterService$Batcher.run(MasterService.java:135) [elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.TaskBatcher.runIfNotProcessed(TaskBatcher.java:150) [elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.TaskBatcher$BatchedTask.run(TaskBatcher.java:188) [elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingRunnable.run(ThreadContext.java:681) [elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.common.util.concurrent.PrioritizedEsThreadPoolExecutor$TieBreakingPrioritizedRunnable.runAndClean(PrioritizedEsThreadPoolExecutor.java:252) [elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.common.util.concurrent.PrioritizedEsThreadPoolExecutor$TieBreakingPrioritizedRunnable.run(PrioritizedEsThreadPoolExecutor.java:215) [elasticsearch-6.8.6.jar:6.8.6]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
[2020-07-29T11:58:24,670][DEBUG][o.e.a.b.TransportShardBulkAction] [graylog1-graylog] [graylog_2787][2] failed to execute bulk item (index) index {[graylog_deflector][message][0a42e010-d182-11ea-9fa3-005056a775aa], source[anonymization]}
at org.elasticsearch.cluster.service.MasterService.runTasks(MasterService.java:200) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.MasterService$Batcher.run(MasterService.java:135) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.TaskBatcher.runIfNotProcessed(TaskBatcher.java:150) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.cluster.service.TaskBatcher$BatchedTask.run(TaskBatcher.java:188) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingRunnable.run(ThreadContext.java:681) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.common.util.concurrent.PrioritizedEsThreadPoolExecutor$TieBreakingPrioritizedRunnable.runAndClean(PrioritizedEsThreadPoolExecutor.java:252) ~[elasticsearch-6.8.6.jar:6.8.6]
at org.elasticsearch.common.util.concurrent.PrioritizedEsThreadPoolExecutor$TieBreakingPrioritizedRunnable.run(PrioritizedEsThreadPoolExecutor.java:215) ~[elasticsearch-6.8.6.jar:6.8.6]
[2020-07-29T11:58:24,686][INFO ][o.e.c.m.MetaDataMappingService] [graylog1-graylog] [graylog_2787/Tb9VBXgjSuCtg_rZWO_JVw] update_mapping [message]
