Graylog Standby & Upgrade
Hi, i want to upgrade my Graylog(v2.4.6) and Elasticsearch(v5.6) environment. And also I want to create a standby environment for current environment.
So i have just thought, what if i create another environment with latest versions of Graylog and Elasticsearch with latest stable versions, then i move my current environment completely to that new environment. Do services work properly? Or what do you suggest?
Hello, Mfurkandemir,
Welcome to the community! We’re glad you’re here!
I’ve moved your question to our Daily Challenges where you may get more feedback.
What OS are you on?
Similar post in the community:
Upgrade Graylog 2.4 to 4.x - #3 by aaronsachs
For Elastic:
Elastic 7.0 is likely to cause issues if upgrading due to security improvements in the newer version.
Thanks for replying, I’m running these services on redhat7
