Just realize something, 5044 is the port of Default TCP input that Graylog normally start.
Take a look if it is running at http://10.119.113.199:9000/system/inputs (change here to the address of your graylog UI)
You should see something like:
Thank you so much, it just fixed the error. Never knew i hav to set in the input (graylog UI). I hav other inputs like TCP and UDP but unfortunately missed to configure this. Thank you so much.
