Graylog Sidecar (1.5.1) fails (in fact Filebeat fails)
The filebeat agent fails after working approx. 30 minutes or longer with this error:
runtime/cgo: pthread_create failed: Operation not permitted
SIGABRT: abort
PC=0x7fbcf68a8dfc m=5 sigcode=18446744073709551610
There several identical servers, only on some we get this error.
  • OS Information: Server: RHEL 8.10, Client: SLES15SP7
  • Package Version: Graylog Server: 7.0.3, Graylog sidecar: 1.5.1 (RPM Package)
The deployed sidecar configuration is this:
# Required settings
fields_under_root: true
output.logstash:
hosts: [“10.2.3.100:5044”]
path:
data: ${sidecar.spoolDir!“/var/lib/graylog-sidecar/collectors/filebeat”}/data
logs: ${sidecar.spoolDir!“/var/lib/graylog-sidecar/collectors/filebeat”}/log
filebeat.inputs:
type: filestream
enabled: true
paths:
/var/log/apache2/access.log
/var/log/apache2/error.log
/var/log/httpd/access_log
/var/log/httpd/error_log
tags: [“linux”,“anwendung”,“loadbalancer”]
fields:
event_source_product: apache_httpd
type: filestream
enabled: true
paths:
/apps/anwendung/webviewer/wrapper_prod_ports-default.log
tags: [“linux”,“anwendung”,“webviewer_wrapper”]
multiline.pattern: ‘^\w+\s+|\s+jvm 1\s+| \d{4}/\d{2}/\d{2} \d{2}:\d{2}:\d{2} | [\d{4}.*$’
multiline.negate: true
multiline.match: after
type: filestream
enabled: true
paths:
/apps/anwendung/viewerservlet/wrapper_prod_ports-default.log
tags: [“linux”,“anwendung”,“viewerservlet_wrapper”]
type: filestream
enabled: true
paths:
/apps/anwendung/webviewer/apache-tomcat-9.0.104/logs/localhost_access_log.20*.log
/apps/anwendung/viewerservlet/apache-tomcat-9.0.104/logs/localhost_access_log.20*.log
tags: [“linux”,“anwendung”,“webviewer”]
exclude_lines: [‘./webviewer/rest/ela/user/userinfo.’,
‘./webviewer/rest/info/license.’,
‘./webviewer/VERSION.txt.’,
‘./images/toolbarButton-.’,
‘./webviewer/rest/info/version.’,
‘./webviewer/rest/documents/list.’,
‘./webviewer/rest/ela/annotation/config/show-generic-annotations.’,
‘./webviewer/rest/desk/.’,
‘./webviewer/rest/ela/annotation/templates.’,
‘./webviewer/login.’,
‘./webviewer/webjars/ui/index.html.’,
‘./webviewer/rest/ela/user/register.’,
‘./webviewer/rest/info/commit.’,
‘./webviewer/rest/ela/user/userid?.’,
‘./webviewer/rest/ui/configs?component.’]
Is there a problem in the configuration?
Thansk in advance,
Dietmar
@schurd Doing a quick search it could be related to the amount of log files the filebeat instance is having to track and with that thread exhaustion.
You can try increasing the thread usage available to the user running the Sidecar service although it could be an limit at a hardware level.
Hello Wine_Merchant,
thanks a lot for the hint. I will try to increase the thread amount. But the number of log files is not high, I would estimate 4 to 8 log files to transfer to graylog.
In the Sidecar configuration I removed the “exclude_lines”. Now the problem occurs less often.
Regards,
Dietmar
I increased the thread level with
max_procs: 4
Now I don’t get those errors anymore. I hope they won’t come back again.
Thanks for the hint!
Dietmar
Good to hear, thanks for the update!
