Graylog server not listening to port 9000 after reinstalling
I’ve reinstalled graylog version 3.0.2 on centos. I’ve updated the server.conf file and started the graylog service but port 9000 is not listening.
Showing below info while checking the graylog-server status:
[root@HYD-VNOC-STG-ZABBIX ~]# service graylog-server status
   Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; disabled; vendor preset: disabled)
   Active: active (running) since Mon 2022-01-24 12:31:42 IST; 1h 56min ago
     Docs: http://docs.graylog.org/
 Main PID: 17711 (graylog-server)
   CGroup: /system.slice/graylog-server.service
           ├─17711 /bin/sh /usr/share/graylog-server/bin/graylog-server
           └─17712 /usr/bin/java -Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -jar -Dlog4j.configu...
Jan 24 12:31:50 HYD-VNOC-STG-ZABBIX graylog-server[17711]: at com.google.inject.internal.RealMultibinder$RealMultibinderProvider.doProvision(RealMultibinder.java:151)
Jan 24 12:31:50 HYD-VNOC-STG-ZABBIX graylog-server[17711]: at com.google.inject.internal.InternalProviderInstanceBindingImpl$Factory.get(InternalProviderInstanceBindingImpl.java:113)
Jan 24 12:31:50 HYD-VNOC-STG-ZABBIX graylog-server[17711]: at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:42)
Jan 24 12:31:50 HYD-VNOC-STG-ZABBIX graylog-server[17711]: at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:65)
Jan 24 12:31:50 HYD-VNOC-STG-ZABBIX graylog-server[17711]: at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:113)
Jan 24 12:31:50 HYD-VNOC-STG-ZABBIX graylog-server[17711]: at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
Jan 24 12:31:50 HYD-VNOC-STG-ZABBIX graylog-server[17711]: at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
I am unable to trace the issu. Can someone help me resolving this issue.
Thanks,
Hello @divakar525
It would help to show your Graylog Config, if possible and your Graylog logs.
