Hi there,
i have a problem with my graylog search:
I have a field which contains the length of a Domain as a Number. If i do the following search over the past 5 minutes i do not get the result i was expecting.
DNS_DomainLength:>40
I want to get only messages where the Domain is longer then 40 Chars (which should be done with this query i guess), but i also get messages where the domain is less than 40. If i do this query: DNS_DomainLength:40 it works like it should.
I also tried it with range {}[] or with AND but it doesnt work. I also tried to convert it to int to see if it does make a difference (which should not cause of elasticsearch)
Greetings Merasil
