Graylog query with regular expression to filter working hours
My objective here is to determine how many times my PCs are being rebooted but I am only interested if this happens during business hours.
My PCs are all Win7 and I am using NXlog to collect the logs, the log that tells me that a PC has been rebooted are
2018-09-16 02:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 08:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 01:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 10:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 11:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 13:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 19:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 23:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 16:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 22:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 17:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 21:37:16 testpc.local INFO 6006 The Event log service was stopped.
2018-09-16 15:37:16 testpc.local INFO 6006 The Event log service was stopped.
So this is my sample data.
My though here is that I could query the logs using a regular expression to find the events during business hour. For that I came up with this regex.
\d{4}-\d{2}-\d{2} (08|09|10|11|12|13|14|15|16|17)
Which I have validated here:
And in looking at the documentation for elastic search here
https://www.elastic.co/guide/en/elasticsearch/reference/5.6/query-dsl-regexp-query.html#regexp-syntax
it says that the regex has to match the entire field
"Lucene’s patterns are always anchored. The pattern provided must match the entire string"
So, based on this I added " .* " to my query, which now is
\d{4}-\d{2}-\d{2} (08|09|10|11|12|13|14|15|16|17).*
So in graylog my complete query is:
/^\d{4}-\d{2}-\d{2} (08|09|10|11|12|13|14|15|16|17)/ AND “The Event log service was stopped” AND EventID:6006
But for some reason that I cant understand this is not working for me, it is not returning anything.
My Graylog version is 2.4.5
Any help will be much appreciated.
If you do not place a field to search before the timestamp it will be searched in the field message, full_message and source but not timestamp.
I would easy that all up a little, adding a processing pipeline that gives you the indicator if the message is withing the working hours or not. That would look like:
rule "Between 9 and 17"
  to_date($message.timestamp).hourOfDay >= 9 &&
  to_date($message.timestamp).hourOfDay <= 17
  set_field("trigger_alert", true);
Then you can search for _exists_:trigger_alert AND EventID:"6006" and whatever you want to add to that search and save your query a complex regex.
Thanks a lot for your super quick response.
I also did the query specifying the filed with is this case is the “message” field. but same result
My apologies I am not familiar with processing pipelines, once added will that apply to my data already in captured ?
I just looked in older post and I see it is not possible to re-process Graylog logs
So in my particular case where I already have the logs, adding the pipeline (thanks for the tip, it seems pretty cook) will not help me.
So I somehow need to make my regex work on the messages field.
Any idea much appreciated
If anyone has any idea why my regex is not working, I will appreciate your input.
For now, it seems to me like Graylog GUI is not able to handle complex regex, but not sure about that
Thanks,
Could You paste the whole message as it is in graylog. Ex:
EventReceivedTime
2018-09-27T08:53:24.047843+02:00
FileName
some/name
SourceModuleName
file
SourceModuleType
im_file
app
app
file
filename
hostname
hostnmae
log
Here will be some log
message
{“EventReceivedTime”:“2018-09-27T08:53:24.047843+02:00”,“SourceModuleName”:“asdasd”,“SourceModuleType”:“im_file”,“FileName”:“asdasdasd”,“log”:“2018-09-27 08:53:23:516asdasdasd”,“hostname”:“asdasd”}
requestId
21323
sessionId
123213213
source
source
timestamp
2018-09-27T06:53:24.057Z
Here is the message:
AccountName
SYSTEM
AccountType
User
Category
Task engine properly shut down
Channel
Microsoft-Windows-TaskScheduler/Operational
Domain
NT AUTHORITY
EventID
318
EventReceivedTime
2018-09-27 09:49:31
EventType
INFO
Keywords
-9223372036854776000
Opcode
Stop
OpcodeValue
2
ProcessID
1076
ProviderGuid
{DE7B24EA-73C8-4A09-985D-5BDADCFA9017}
RecordNumber
236452
Severity
INFO
SeverityValue
2
SourceModuleName
windows_events_logs
SourceModuleType
im_msvistalog
SourceName
Task
318
TaskEngineName
S-1-5-18:NT AUTHORITY\System:Service:
ThreadID
5840
UserID
S-1-5-18
Version
0
full_message
Task Scheduler shutdown Task Engine “S-1-5-18:NT AUTHORITY\System:Service:” process.
host_ip
192.168.100.202
level
6
message
2018-09-27 09:49:30 testpc.local INFO 318 NT AUTHORITY\SYSTEM Task Scheduler shutdown Task Engine “S-1-5-18:NT AUTHORITY\System:Service:” process.
source
testpc.local
timestamp
2018-09-27T14:49:30.000Z
It is a standard Windows log message generated with NXLog
I’ve tried on my logs and I believe this is impossible due to construction of elasticsearch indexing. Tried in Kibana, this doesn’t behave predictably.
@madi, thanks for trying this at least I know it is not only me.
To any sysadmin that might find this post via google. the solution I finally implemented is based on the suggestion from @jan, but the rule has to be modified as there is a data type consistency issue, the rule I ended up implementing is:
rule “business hour flag”
to_long(to_date($message.timestamp).hourOfDay) >= 9 &&
to_long(to_date($message.timestamp).hourOfDay) <= 21 &&
to_long(to_date($message.timestamp).dayOfWeek) >= 1 &&
to_long(to_date($message.timestamp).dayOfWeek) < 6
set_field(“work_hours”, true);
Essentially one has to add the to_long to be able to do the comparison.
Still this does not solve my base problem, as I have a ton of logs already in Graylog and I cant apply this pipeline to those, but at least I process new logs as I wanted.
Another problem I have is GL seems to not be respecting TimeZone (in my case “America/New_York”), so I had to do the >= and <= based on UTC which is the default Timezone, so if I would do say:
to_long(to_date($message.timestamp).hourOfDay, “America/Toronto”)
It does not like it and my rule just fails, but I will probably add a different post for that one.
I guess @malexdno that we need to document better - Graylog is working internally with UTC.
You could open a feature request to be able to work with the timezone in this.
Thanks a lot @jan for your response, I am glad to know I am not going crazy, I have been very confused with reading the documentation and things not working. Documentation is fundamental and I am 100% sure you guys will look into that side of things.
As for timezone, I will create a feature request and in my particular case, it is timezone and be able to manage daylight savings, I took a quick look at the code and it does not seem like a trivial thing to implement as I see a lot of other functionalities are based on UTC. Probably the best way (and I might try this) is a plugin.
