Graylog Open: Active Directory Group Membership
I am attempting to set up Active Directory authentication. I can successfully authenticate users in the domain with this base DN and search pattern:
dc=mydomain;dc=local(&(objectClass=user)(|(sAMAccountName={0})(userPrincipalName={0})))
The goal is to create a security group within AD (“Graylog Admins”), assign users to this group, and only allow users of the group to log into Graylog. Thus, I have the search pattern:
(&(objectClass=user)(|(sAMAccountName={0})(userPrincipalName={0}))(memberOf=CN=Graylog Admins,OU=Service Users,DC=mydomain,DC=LOCAL))
I have tried this - and every other query that I can think of - to make this work, but I always end up with “User does not exist.” What is the proper way to allow only members of a certain group, login access to Graylog Open?
  • OS Information: Almalinux 8.6, Linux 4.18.0-372.26.1.el8_6.x86_64
  • Package Version: Graylog 4.2.12+2c655fb
You want to work under Group Synchronization. Set your Group Search Base DN to be the OU where the AD group is you are working with: (Assumes the graylog_admins group is in the OU BAT_ROLES
OU=BAT_ROLES,OU=BAT_ROOM,DC=BATCAVE, DC=LOCAL
Set your Group Search Pattern:
(&(objectClass=group)(cn=graylog_admins))
The rest is up to you but that should get you most of the way there!
