Graylog Mysql Fields
Dear All,
We are shipping mariadb (10.3.8 and 5.5.56) logs on Centos 7 to our Gralog server using NxLog as shown below:-
I know the field format of the mariadb log.
[timestamp],[serverhost],[username],[host],[connectionid],
[queryid],[operation],[database],[object],[retcode]
What I want to do is to insert key pairs to the value of fields.
Example
Original
20180710 11:01:21,centos2,root,localhost,3,12,QUERY,customers,‘select * from users’,0
Becomes
timestamp=20180710 11:01:21,hostname=centos2,user=root,connect_id=localhost,query_type=QUERY,database=customers,query=‘select * from users’,ret_code=0
Could I do this using a GROK filter or maybe a pipeline rule, but I found there are no keys in the original message to use the pipeline key value extractor for example. The fields are fixed.
Any help appreciated.
Kind Regards
Jake
He,
if the fields are fixed, then just create a GROK Pattern or similar to extract them. That should be the easiest way to get your data seperated.
I have something like the following to extract mySQL Slow logs
rule "mysql: extract slow query log"
  has_field("type") && to_string($message.type) == "mysql-slow"
 let message_field = to_string($message.message);
 let action = grok(pattern: "(?s) User@Host: (?:%{USERNAME:mysql_clientuser})(?:%{GREEDYDATA}) @ (?:%{DATA:mysql_clienthost}) \\[(?:%{DATA:mysql_clientip}\\]) %{GREEDYDATA} Query_time: %{NUMBER:mysql_querytime}(?:%{SPACE})Lock_time: %{NUMBER:mysql_locktime}(?:%{SPACE})Rows_sent: %{NUMBER:mysql_rowssent}(?:%{SPACE})Rows_examined: %{NUMBER:mysql_rowsexamined}(?:%{SPACE})(?:%{GREEDYDATA})SET timestamp=%{NUMBER:mysql_timestamp}\\;(?:%{GREEDYDATA:mysql_slow_query})\\;", value: message_field, only_named_captures: true);
 set_fields(action);
Hi Jan,
Is this about right for the GROK pattern, it is my first time writing one. It is a little weird as I am used to regex!
Original data
GROK Pattern
%{GREEDYDATA:datestamp}\s%{TIME:time},%{HOSTNAME:host},%{USERNAME:user},%{WORD:connected_id},%{NUMBER:query_id1},%{NUMBER:query_id2},%{WORD:database},%{GREEDYDATA:query_executed},%{NUMBER:ret_code}
This would give us as a pipeline rule
rule “mysql: extract query log”
has_field(“type”) && to_string($message.type) == “mysql”
let action = grok(pattern: “%{GREEDYDATA:datestamp}\s%{TIME:time},%{HOSTNAME:host},%{USERNAME:user},%{WORD:connected_id},%{NUMBER:query_id1},%{NUMBER:query_id2},%{WORD:database},%{GREEDYDATA:query_executed},%{NUMBER:ret_code};”, value: message_field, only_named_captures: true);
set_fields(action);
What do you think?
Cheers
Jake
According to the GROKdebugger that should work - when removing the last ; and replace the \s with %{SPACE}
%{NUMBER:datestamp}%{SPACE}%{TIME:time},%{HOSTNAME:host},%{USERNAME:user},%{WORD:connected_id},%{NUMBER:query_id1},%{NUMBER:query_id2},%{WORD:database},%{GREEDYDATA:query_executed},%{NUMBER:ret_code}
Hi Jan,
And boom , we have success
Kind Regards
Jake
Make sure to share your extractors and pipelines on the Graylog Marketplace: https://marketplace.graylog.org/ :wink:
