Graylog multi-node with docker swarm
Hello everyone!
I would like to share a communication problem on nodes in graylog using docker swarm.
Contextualizing:
I’m currently testing creating the graylog environment on 5 servers to have the load distributed, and I’m using swarm to make the environment easier to scale.
Swarm Servers:
root@graylog-cluster-0001:~# docker node ls
ID                            HOSTNAME               STATUS              AVAILABILITY        MANAGER STATUS      ENGINE VERSION
kmuryq6mo33m9nsknm8m2i0h1 *   graylog-cluster-0001   Ready               Active              Leader              18.09.5
etpae23nhf68c11cga9rdbxnj     graylog-cluster-0002   Ready               Active                                  18.09.5
q57rve8vignpab338o9dxudpf     graylog-cluster-0003   Ready               Active                                  18.09.5
n6o7wv5ibt2qq53u5p9dnlxrk     graylog-cluster-0004   Ready               Active                                  18.09.5
ut927bkotqjntjey8uewlutfj     graylog-cluster-0005   Ready               Active                                  18.09.5
I am using the following code stack to raise the environment:
root@graylog-cluster-0001:~/docker-elk# cat docker-stack.yml
version: '3.3'
services:
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.6.1
    ports:
      - "9200:9200"
      - "9300:9300"
    configs:
      - source: elastic_config
        target: /usr/share/elasticsearch/config/elasticsearch.yml
    environment:
      ES_JAVA_OPTS: "-Xmx2g -Xms2g"
    volumes:
      - /nfs/elastic:/usr/share/elasticsearch/data
    networks:
      - elk
    deploy:
      mode: replicated
      replicas: 1
  mongo:
    image: mongo:3
    volumes:
      - /nfs/mongo:/data/db
    networks:
      - elk
    deploy:
      mode: replicated
      replicas: 1
  graylogfwbv:
    image: graylog/graylog:3.0.1
    environment:
      - GRAYLOG_PASSWORD_SECRET=somepasswordpeppersdfdsfsfsadf
      # Password: admin
      #- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
      - GRAYLOG_ROOT_PASSWORD_SHA2=8d969eef6ecad3c29a3a629280e686cf0c3f5d5a86aff3ca12020c923adc6c92
      - GRAYLOG_IS_MASTER=false
    depends_on:
      - mongo
      - elasticsearch
      - graylogmaster
    ports:
      - 30010:30000/udp
    networks:
      - elk
    deploy:
      mode: replicated
      replicas: 1
  graylogfortigates:
    environment:
      # Password: admin
    depends_on:
      - mongo
      - elasticsearch
      - graylogmaster
    ports:
      - 30020:30000
    networks:
      - elk
    deploy:
      mode: replicated
      replicas: 1
  grayloggeral:
    environment:
      # Password: admin
        #- GRAYLOG_NODE_ID=de305d54-75b4-431b-adb2-eb6b9e5geral
    depends_on:
      - mongo
      - elasticsearch
      - graylogmaster
    ports:
      - 1514:1514
      - 5414:5414
      - 5414:5414/udp
      - 12201:12201/udp
      - 30020:30020/udp
    networks:
      - elk
    deploy:
      mode: replicated
      replicas: 1
  graylogmaster:
    environment:
      # Password: admin 123456
      - GRAYLOG_HTTP_EXTERNAL_URI=http://200.xxx.xxx.xxx:9000/
      - GRAYLOG_IS_MASTER=true
      #- GRAYLOG_HEAP_SIZE="-Xms3g -Xmx3g"
      #configs:
      #- source: graylog_config
      #  target: /etc/graylog/server/node-id
    depends_on:
      - mongo
      - elasticsearch
    ports:
      - 9000:9000
    networks:
      - elk
    deploy:
      mode: replicated
      replicas: 1
  kibana:
    image: docker.elastic.co/kibana/kibana-oss:6.6.1
    ports:
      - "5601:5601"
    configs:
      - source: kibana_config
        target: /usr/share/kibana/config/kibana.yml
    networks:
      - elk
    deploy:
      mode: replicated
      replicas: 1
configs:
  elastic_config:
    file: ./elasticsearch/config/elasticsearch.yml
  kibana_config:
    file: ./kibana/config/kibana.yml
networks:
  elk:
    driver: overlay
To start the environment use the command
# docker stack deploy -c docker-stack.yml elk
As a test environment I’m using the docker visualizer to know where each container is located.
# docker service create --name=viz --publish=8080:8080/tcp --constraint=node.role==manager --mount=type=bind,src=/var/run/docker.sock,dst=/var/run/docker.sock dockersamples/visualizer
The main issue is the communication between the graylog nodes, in the image below everything is working correctly!
However when I remove all swarm services (simulating a physical server problem)
# docker service rm $(docker service ls -q)
I try to start the graylog stack again
The communication between graylog nodes no longer occurs as expected:
Close the services again and start the communication again between the nodes again
Looking at the graylog master logs, it looks like they are not able to access the other nodes, log:
# docker logs elk_graylogmaster.1.2d0wduulcd33n8cs7w6jzpfde
2019-04-21 16:25:44,881 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call http://172.18.0.3:9000/api/system on node <caa1f9ce-28c3-486a-949a-897423c79ddf>
java.net.ConnectException: Failed to connect to /172.18.0.3:9000
	at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:247) ~[graylog.jar:?]
	at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:165) ~[graylog.jar:?]
	at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:257) ~[graylog.jar:?]
	at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:135) ~[graylog.jar:?]
	at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:114) ~[graylog.jar:?]
	at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126) ~[graylog.jar:?]
	at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
	at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
	at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
	at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_212]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_212]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_212]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
Caused by: java.net.ConnectException: Connection refused (Connection refused)
	at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_212]
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_212]
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_212]
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_212]
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_212]
	at java.net.Socket.connect(Socket.java:589) ~[?:1.8.0_212]
	at okhttp3.internal.platform.Platform.connectSocket(Platform.java:129) ~[graylog.jar:?]
	at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:245) ~[graylog.jar:?]
	... 26 more
2019-04-21 16:25:45,846 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call http://172.18.0.3:9000/api/system/metrics/multiple on node <caa1f9ce-28c3-486a-949a-897423c79ddf>
	... 26 more
2019-04-21 16:25:47,846 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call http://172.18.0.3:9000/api/system/metrics/multiple on node <caa1f9ce-28c3-486a-949a-897423c79ddf>
	... 26 more
2019-04-21 16:25:49,845 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call http://172.18.0.3:9000/api/system/metrics/multiple on node <caa1f9ce-28c3-486a-949a-897423c79ddf>
	... 26 more
2019-04-21 16:25:49,879 WARN : org.graylog2.shared.rest.resources.ProxiedResource - Unable to call http://172.18.0.3:9000/api/system on node <caa1f9ce-28c3-486a-949a-897423c79ddf>
<omitted the rest of the output>
I already checked:
Communication between the servers, all are within the same network, and communication between them is ok.
Graylog service, doing a 127.0.0.1 curl on each node the graylog responds correctly.
Detail
I noticed that restarting the docker service on all hosts sometimes the communication between the nodes goes back to working again
As I said I’m just testing the environment, I’m learning to use graylog and docker swarm, so I wonder if anyone has already gone through this.
I feel that the problem may be related to docker, since restarting the service sometimes working, but if someone with more experience could pass some techniques of how to do the troublehshotting.
Thank you very much
He
hope you error is fixed. But that each node is able to communicate with each other is vital for Graylog - why this is not working in your setup can’t be predicted by any other than you. What you have done is not wrong, but make this setup stable and reliable isn’t possible from the outside.
I didn’t have this kind of setup so I’m not aware of this issue - it might be that you have issues with the public URI when you restart the container: http://docs.graylog.org/en/3.0/pages/configuration/server.conf.html#web-rest-api
But that would your logs show finally.
Hello Jan.
I tested a lot of things, but I did not achieve stability in communication between nodes. Anyway, I’ll try to create the environment without using swarm, creating a simple docker file on each host, it will be less flexible, but I believe it will meet the graylog cluster needs.
I would like to take a question with you.
Does the order that the hosts of a graylog cluster start makes a difference?
That was one of my concerns.
Thank you very much for trying to help me with the settings.
MongoDB and Elasticsearch should be running before Graylog starts …
