Graylog logs are not receiving
I’m not receiving windows logs, every time check alert there is exclamation next to graylog gl2_source_collector:35fac341-e225-44cb-8018-9973589a21f5 and says
Unknown field : Query contains unknown field: gl2_source_collector
Here is my configuration
Needed for Graylog
fields_under_root: true
fields.source: ${sidecar.nodeName}
output.logstash:
hosts: [“192.168.233.135:5044”]
path:
tags:
  • windows
    winlogbeat:
    event_logs:
    • name: Application
    • name: System
    • name: Security
Hello && Welcome @rsuthar
What type did you use, beats or beats (legacy) as your input?
I’m using beats 1.2 on graylog 4.3
I was referring to your INPUT being used. The 1.2 is sidecar version but that good to know.
Example:
You may need to post you sidecar.conf.
If you are available, please connect remote any desk. I’m using Beats not beats (deprecated ) it’s lab test before production deployment.
Hey,
my guess is that no log has been received yet.
Therefore the field (gl2_source_collector) is not indexed.
Maybe the command graylog-sidecar -debug will help?
Thanks I will try graylog-sidecar -debug
