I’m using a pretty simple search, I have graylog track my API request and responses. I’m trying to look for response_content
that come in with empty curly brackets.
- Package Version: Graylog 5.0.6+51f2df8
Here is the field that I’m trying to query:
When I click on Add to Query
in that field, this gets appended to my search AND response_content:\{\}
I’ve also tried different variations:
- Regex:
response_content:/\{\\}/
- Quotes
response_content:"{}"
None of these seem to surface any logs, removing this specific search query does generate logs. []
brackets seems to work just fine though.
Wondering if someone might help with pointing out what I’m doing wrong, or if curly brackets are generally not well supported.
