I am using Docker to deploy graylog, 1 datanode, elasticsearch, and mongodb. After running “docker compose up -d”, I am able to access the Graylog Initial Setup screen, where I:
- See the datanode is visible in the UI
- Create a CA
- Create the CA policy
- Provision certificate and continue, to push the CA to the datanode
- The Initial Setup UI reports this error on the datanode: “TOO MANY FOLLOW-UP REQUESTS: 21”
I am running Docker on Windows with WSL2. This is my docker-compose.yml:
version: ‘2’
services:
mongodb: # Mongodb service
image: mongo #
volumes:
- mongo_data:/data/db # Persisted mongodb data
elasticsearch: # ElasticSearch service
image: docker.elastic.co/elasticsearch/elasticsearch:8.12.0 # Version of elasticsearch image
volumes:
- es_data:/usr/share/elasticsearch/data # Persisted elasticsearch data
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=0.0.0.0
- “ES_JAVA_OPTS=-Xms512m -Xmx512m”
ulimits:
# Unlimited amount of memory set for elasticsearch container
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
image: graylog/graylog:5.2.3 # Version of Graylog docker image
volumes:
- graylog_data:/usr/share/graylog/data # Persisted Graylog data
environment:
- GRAYLOG_PASSWORD_SECRET=“<snipped”
- GRAYLOG_ROOT_PASSWORD_SHA2=“<snipped”
- GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
- GRAYLOG_WEB_ENDPOINT_URI=http://127.0.0.1:9000/api
entrypoint: /usr/bin/tini – wait-for-it elasticsearch:9200 – /docker-entrypoint.sh
links:
- mongodb:mongo
- elasticsearch
restart: always
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
datanode1:
image: graylog/graylog-datanode:5.2.3
hostname: “datanode1”
depends_on:
- mongodb
environment:
GRAYLOG_DATANODE_NODE_ID_FILE: “/var/lib/graylog-datanode/node-id”
GRAYLOG_DATANODE_PASSWORD_SECRET: “<snipped”
GRAYLOG_DATANODE_ROOT_PASSWORD_SHA2: “<snipped”
GRAYLOG_DATANODE_MONGODB_URI: “mongodb://mongodb:27017/graylog”
ulimits:
memlock:
hard: -1
soft: -1
nofile:
soft: 65536
hard: 65536
ports:
- “8999:8999/tcp” # DataNode API
volumes:
- “graylog-datanode-01:/var/lib/graylog-datanode”
restart: “on-failure”
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_data:
driver: local
driver: local
- Service logs, configurations, and environment variables:
I checked the logs from the graylog container:
2024-02-02 16:03:35,185 INFO : org.graylog2.security.CustomCAX509TrustManager - CA changed, refreshing trust manager
2024-02-02 16:04:36,737 INFO : org.graylog2.bootstrap.preflight.GraylogCertificateProvisioningPeriodical - Starting connectivity check with node 8fdf6c84-dce1-43cf-813c-1d487ed4e59b, silencing error messages for 60 seconds.
2024-02-02 16:05:38,236 WARN : org.graylog2.bootstrap.preflight.GraylogCertificateProvisioningPeriodical - Error trying to connect to data node 8fdf6c84-dce1-43cf-813c-1d487ed4e59b: Too many follow-up requests: 21, retrying (attempt #21)
And the Graylog datanode container logs show:
2024-02-02T16:03:35.879Z INFO [CustomCAX509TrustManager] CA changed, refreshing trust manager
2024-02-02T16:03:36.168Z ERROR [CustomCAX509TrustManager] Could not add Graylog CA to TrustManagers: Failed to load keystore from Mongo collection for node GRAYLOG CA
org.graylog.security.certutil.ca.exceptions.KeyStoreStorageException: Failed to load keystore from Mongo collection for node GRAYLOG CA
at org.graylog.security.certutil.keystore.storage.KeystoreMongoStorage.readKeyStore
I see connections from the datanode to the mongo instance, so I don’t think its network related. But, I’m not sure how to proceed in isolating the datanode to mongo issue.
I need help to understand how to successfully update the trust manager on the datanode, or suggestions on how to workaround this issue to ensure communications are still secure.
