Edit: Everything works, I just converted the private key incorrectly
Graylog fails on launch when https mode is enabled, with this rather cryptic error, that seems to be about the keystore. Original issue was it being unable to read the private key but I managed to fix that, can’t delete this post
OS Information: RHEL9
Package Version: 6.1.8 (graylog-server)
Edit: I can only post one image at a time, I’ll reply with more if needed or I’ll use Imgur.
I’ve followed this guide, mostly, with the exception of creating the certificate as I had my own CA in my homelab.
The only possible reason is that my key is in EC and I’ve seen reports of EC keys not working but that was back in 2016.
Did I do something wrong? Need some pointers, thanks!
