Lets suppose if I am injegsting logs through standard syslog which does not conform with standard syslog RFC; would it be possible to parse the logs in graylog once they hit Graylog? Or do I need to put logstash in between and then work on GROK patterns?
Can someone please advise?
And if changing logos and NASA image is the same procedure with 2.4 as well?
Yes Blason. If it’s non-standard RFC, it will not parse automatically but you can create Grok patterns from graylog to apply to the messages as they are coming in. You can either apply the extractor to the input or use the grok function in a pipeline.
I’d recommend using Grok debug (https://grokdebug.herokuapp.com) to write a pattern that will work on the logs and then read up on extractor or the grok function in the pipeline to apply the pattern.
For non-RFC messages I would recommend using the RAW Input and then parse the messages like @megan201296 suggested.
Changing Logos, Images and Colors in Graylog is only able when you download the source, change the parts you want to change and then compile your personal graylog.
