Hello every one.
I recently have saturation on graylog. (var/ was full on my server). So I delete older indexes, from Graylog UI (System/Indices).
But graylog won’t write into elasticsearch anymore (out msg/s still at 0)
I try to recalculate index ranges and Rotate active write index but nothing change.
I tried to restart my server, nothing change to (mangoDB, elasticsearch and Graylog are running)
I don’t know what to do
Please forgive my approximate English I am not
Best regards
jan
(Jan Doberstein)
2
he @shinji7800
what did you find in your server.log or the elasticsearch log? In addition what Graylog version did you use?
hello thanks for your reply
graylog-server/server.log don’t move
but 1 Gb of logs in 2 days for /elasticsearch/graylog.log
With in appearance only
All shards failed for phase [query]
java.lang.IllegalArgumentException: Expected numeric type on field [source], but got [text]
Graylog 2.3.2 on RHEL 7
jan
(Jan Doberstein)
4
your issue might have multiple reasons, but you need to check them on your own.
- the Graylog journal might be corrupt because the filesystem was full
- the elasticsearch indices are in read only mode because the filesystem was full
- your elasticsearch server/data is corrupt
- the error message you have indicate that the elasticsearch server is not “green” - https://www.datadoghq.com/blog/elasticsearch-unassigned-shards/
thank you for give me hints to explore !
I let you know
best regards
hi
in Graylog UI/index set and via curl elasticseach is “green”
1 node
1 data nodes
16 active primary shards
16 active shards
the others value are 0
active shards percent as number 100.00
in graylog
evrything is green with this message :
4 indices with a total of {number going up every second} messages Under management
I Wonder if I is note better to erase all data …
for people can loose data …
I delete evey indices,
delete my extractors,
delete my host files,
and reload my server …
It works now
