Graylog (Docker Compose) Wont Start: Java/Permission Errors
Hi there. I’m new to Graylog and have tried searching these forums as well as wider Google searches but not coming up with the same issue. So trying here.
I successfully got Graylog up in running using Docker Compose on a test Alma Linux 9 VM with no issues. However when trying the same process on a Debian 12 (Proxmox Backup Server) Graylog doesn’t start.
When I start Docker Compose without -d I can see the startup processing which is full errors (see below).
  • OS Information:
    Debian GNU/Linux 12 (bookworm) [PBS]
  • Package Version:
mongo:
image: mongo:6.0.5-jammy
opensearch:
image: opensearchproject/opensearch:2
graylog:
image: graylog/graylog:6.2
mongodb     | {"t":{"$date":"2025-05-15T14:09:06.883+00:00"},"s":"E",  "c":"CONTROL",  "id":20558,   "ctx":"initandlisten","msg":"std::exception in initAndListen, terminating","attr":{"error":"open: Permission denied"}}
opensearch  | BindTransportException[Failed to bind to 0.0.0.0:[9300-9400]]; nested: ChannelException[Unable to create Channel from class class org.opensearch.transport.CopyBytesServerSocketChannel]; nested: InvocationTargetException; nested: NoClassDefFoundError[Could not initialize class sun.nio.ch.ServerSocketChannelImpl]; nested: ExceptionInInitializerError[Exception java.lang.ExceptionInInitializerError [in thread "main"]];
opensearch  | Likely root cause: java.lang.ExceptionInInitializerError: Exception java.lang.ExceptionInInitializerError [in thread "main"]
Plus lots of Java errors:
graylog     | 2025-05-15 17:09:23,027 ERROR: org.graylog2.bootstrap.CmdLineTool - Startup error:
graylog     | java.lang.ExceptionInInitializerError: null
graylog     |   at java.base/sun.nio.ch.FileChannelImpl.<init>(Unknown Source) ~[?:?]
graylog     |   at java.base/sun.nio.ch.FileChannelImpl.open(Unknown Source) ~[?:?]
graylog     |   at java.base/sun.nio.fs.UnixChannelFactory.newFileChannel(Unknown Source) ~[?:?]
Caused by: java.io.IOException: Permission denied
It does give this:
"For complete error details, refer to the log at /usr/share/opensearch/logs/docker-cluster.log"
But being the container (which is now stuck in a boot loop) I can’t get to the docker-cluster.log fast enough to read/grab it.
I’ve run docker compose down and then up again after removing the local files to see if that helps but as these are all self contained Docker images I’m not sure what else I can do?
Other than changing the time zone in the docker-compose.yml I didn’t configure my previous successful deployment so I must be missing something here…
I am hoping someone recognises this and can point me in the right direction?
Like I said as far as I can determine the only difference between my succesfull deployment and this unsuccessful one is that the first was an Alma 9 VM whilst this is Debian 12 physical (whilst actually a Proxmox Backup Server).
On that: I’ll try the deployment steps on a plain Debian 12 VM to rule out Proxmox being the problem here. Will update with the result shortly.
Thank you.
For what it’s worth I’ve carried out some more basic troubleshooting and found:
  1. Docker Compose install process works fine on plain Debian 12 host:
  1. Docker Compose install process does not work fine when attempted on a PBS Debian 12 host:
graylog     |   at java.management/java.lang.management.ManagementFactory.getPlatformMBeanServer(Unknown Source)
graylog     |   at org.graylog2.shared.metrics.MetricRegistryFactory.create(MetricRegistryFactory.java:35)
graylog     |   at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:314)
graylog     |   at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:283)
graylog     |   at org.graylog2.bootstrap.Main.main(Main.java:57)
graylog     | Caused by: java.io.IOException: Permission denied
graylog     |   at java.base/sun.nio.ch.FileDispatcherImpl.init(Native Method)
graylog     |   at java.base/sun.nio.ch.FileDispatcherImpl.<clinit>(Unknown Source)
graylog     |   ... 39 more
graylog exited with code 0
graylog     | wait-for-it: waiting 15 seconds for opensearch:9200
I’ll look further into how Proxmox lock down their implementation of Debian to see what permissions need loosening and report back with my findings for others in a similar position.
