I’m unable to connect with graylog running on Ubuntu.
15:48:38.540 [gelfTcpTransport-1-1] ERROR org.graylog2.gelfclient.transport.GelfTcpTransport - Connection failed: connection timed out: graylog.example.org/185.82.212.199:13999
if you give a little more context - it might happen that someone can guide you … but with the little to nothing information it is nearly impossible.
To name only a view informations that are needed.
Thank you for responding
I’m using graylog 2.4 running on ubuntu, I’m using GELF TCP as an input and its running fine, I’m trying to setup WIFI monitoring using nzyme by lennart koopmann, nzyme is running fine but when i check the logs
$ tail -f /var/log/nzyme/nzyme.log
19:28:44.858 [gelfTcpTransport-1-1] ERROR org.graylog2.gelfclient.transport.GelfTcpTransport - Connection failed: Connection refused: graylog.example.org/185.82.212.199:13999
19:28:46.053 [gelfTcpTransport-1-1] ERROR org.graylog2.gelfclient.transport.GelfTcpTransport - Connection failed: Connection refused: graylog.example.org/185.82.212.199:13999
and your Graylog is running on the above username/ip and the configured port is used for the GELF TCP Input?
What should i do make it work?
Do i need to change Graylog Input Settings or Gray log config file settings ? Help Me
my problem is Nzyme is running but no messages are being collected in Graylog.
Did you configure the Graylog IP/Hostname and Receiver Port in nzyme?
Thank you, i miss configured nzyme.
