Issue: Graylog collector process shows as running when checked with below commands
- /etc/init.d/graylog-collector status
- ps -ef | grep graylog-collector
But actually it is not sending logs when data increase inside log files.
OS: Amazon Linux
OS VERSION_ID=“2017.03"
Graylog Collector Version: 0.5.0.
File: Graylog collector
COLLECTOR_JAVA_DEFAULT_OPTS=”-Xms1024m -Xmx1024m -Djava.library.path=$COLLECTOR_ROOT/lib/sigar"
Thanks,
Amit.
Thread dump of graylog-collector process: -
2017-09-19 05:38:37
Full thread dump Java HotSpot(TM) 64-Bit Server VM (25.141-b15 mixed mode):
"Attach Listener" #157 daemon prio=9 os_prio=0 tid=0x00007fe028001000 nid=0x3b82 waiting on condition [0x0000000000000000]
java.lang.Thread.State: RUNNABLE
Locked ownable synchronizers:
- None
"Keep-Alive-Timer" #156 daemon prio=8 os_prio=0 tid=0x00007fdffc049800 nid=0x3b0a waiting on condition [0x00007fe0078f9000]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(Native Method)
at sun.net.www.http.KeepAliveCache.run(KeepAliveCache.java:172)
at java.lang.Thread.run(Thread.java:748)
- None
"Thread-5" #60 daemon prio=5 os_prio=0 tid=0x00007fdfdc002800 nid=0x5679 waiting on condition [0x00007fe006ff2000]
java.lang.Thread.State: TIMED_WAITING (parking)
at sun.misc.Unsafe.park(Native Method)
- parking to wait for <0x00000000c0ebaee0> (a java.util.concurrent.SynchronousQueue$TransferStack)
at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215)
at java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(SynchronousQueue.java:460)
at java.util.concurrent.SynchronousQueue$TransferStack.transfer(SynchronousQueue.java:362)
at java.util.concurrent.SynchronousQueue.poll(SynchronousQueue.java:941)
at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1073)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1134)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
- None
"GelfSenderThread-39" #39 daemon prio=5 os_prio=0 tid=0x00007fdfe800a000 nid=0x5677 waiting on condition [0x00007fe0070f3000]
- parking to wait for <0x00000000c0ef5450> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078)
at java.util.concurrent.LinkedBlockingQueue.poll(LinkedBlockingQueue.java:467)
at org.graylog2.gelfclient.transport.GelfSenderThread$1.run(GelfSenderThread.java:73)
- <0x00000000c0ef5608> (a java.util.concurrent.locks.ReentrantLock$NonfairSync)
"GelfSenderThread-59" #59 daemon prio=5 os_prio=0 tid=0x00007fdfd4007800 nid=0x5676 waiting on condition [0x00007fe0071f4000]
- parking to wait for <0x00000000c0eb6e88> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- <0x00000000c0eb70b0> (a java.util.concurrent.locks.ReentrantLock$NonfairSync)
"gelfTcpTransport-3-1" #43 daemon prio=5 os_prio=0 tid=0x00007fe074a80800 nid=0x5675 runnable [0x00007fe0072f5000]
at sun.nio.ch.EPollArrayWrapper.epollWait(Native Method)
at sun.nio.ch.EPollArrayWrapper.poll(EPollArrayWrapper.java:269)
at sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:93)
at sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:86)
- locked <0x00000000c0f2cbc0> (a io.netty.channel.nio.SelectedSelectionKeySet)
- locked <0x00000000c0f2cbe0> (a java.util.Collections$UnmodifiableSet)
- locked <0x00000000c0f2cb78> (a sun.nio.ch.EPollSelectorImpl)
at sun.nio.ch.SelectorImpl.select(SelectorImpl.java:97)
at io.netty.channel.nio.NioEventLoop.select(NioEventLoop.java:622)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:310)
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:111)
at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137)
- None
"ChunkProcessor" #42 prio=5 os_prio=0 tid=0x00007fe0749af800 nid=0x5674 waiting on condition [0x00007fe0073f6000]
- parking to wait for <0x00000000c0eae1f8> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.ArrayBlockingQueue.poll(ArrayBlockingQueue.java:418)
at org.graylog.collector.file.ChunkProcessor.run(ChunkProcessor.java:49)
at com.google.common.util.concurrent.AbstractExecutionThreadService$1$2.run(AbstractExecutionThreadService.java:60)
at com.google.common.util.concurrent.Callables$3.run(Callables.java:100)
- None
"chunkreader-scheduler-thread-elasticsearch_logs--0" #41 prio=5 os_prio=0 tid=0x00007fe0749ad800 nid=0x5673 waiting on condition [0x00007fe0074f7000]
- parking to wait for <0x00000000c0ec7dd0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1093)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:809)
at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1074)
- None
"gelfTcpTransport-1-1" #23 daemon prio=5 os_prio=0 tid=0x00007fe0749ab800 nid=0x5672 runnable [0x00007fe0077f8000]
- locked <0x00000000c0f29e98> (a io.netty.channel.nio.SelectedSelectionKeySet)
- locked <0x00000000c0f2b238> (a java.util.Collections$UnmodifiableSet)
- locked <0x00000000c0f29e00> (a sun.nio.ch.EPollSelectorImpl)
- None
"ChunkProcessor" #21 prio=5 os_prio=0 tid=0x00007fe074885800 nid=0x566f waiting on condition [0x00007fe0079fa000]
- parking to wait for <0x00000000c0ebb2c8> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- None
"chunkreader-scheduler-thread-collectd-logs-0" #20 prio=5 os_prio=0 tid=0x00007fe074883800 nid=0x566e waiting on condition [0x00007fe007afb000]
- parking to wait for <0x00000000c0ecb5c0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- None
"ChunkProcessor" #19 prio=5 os_prio=0 tid=0x00007fe074882000 nid=0x566d waiting on condition [0x00007fe007bfc000]
- parking to wait for <0x00000000c02baae0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- None
"chunkreader-scheduler-thread-sensu-logs-0" #18 prio=5 os_prio=0 tid=0x00007fe074880000 nid=0x566c waiting on condition [0x00007fe007cfd000]
- parking to wait for <0x00000000c02ba5f8> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- None
"HeartbeatService" #17 prio=5 os_prio=0 tid=0x00007fe074841000 nid=0x566b waiting on condition [0x00007fe007ffe000]
- parking to wait for <0x00000000c0285458> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
- None
"FileObserver" #15 prio=5 os_prio=0 tid=0x00007fe07483d800 nid=0x5669 waiting on condition [0x00007fe02c1eb000]
- parking to wait for <0x00000000c001c540> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.LinkedBlockingDeque.pollFirst(LinkedBlockingDeque.java:522)
at java.util.concurrent.LinkedBlockingDeque.poll(LinkedBlockingDeque.java:684)
at sun.nio.fs.AbstractWatchService.poll(AbstractWatchService.java:108)
at org.graylog.collector.file.FileObserver.run(FileObserver.java:117)
- None
"BufferProcessor" #14 prio=5 os_prio=0 tid=0x00007fe07483c000 nid=0x5668 waiting on condition [0x00007fe02c2ec000]
java.lang.Thread.State: WAITING (parking)
- parking to wait for <0x00000000c0024018> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039)
at java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:442)
at org.graylog.collector.buffer.MessageBuffer.remove(MessageBuffer.java:62)
at org.graylog.collector.buffer.BufferProcessor.run(BufferProcessor.java:56)
- None
"Thread-2" #13 daemon prio=5 os_prio=0 tid=0x00007fe07464d000 nid=0x5667 runnable [0x00007fe02c882000]
at sun.nio.fs.LinuxWatchService.poll(Native Method)
at sun.nio.fs.LinuxWatchService.access$600(LinuxWatchService.java:47)
at sun.nio.fs.LinuxWatchService$Poller.run(LinuxWatchService.java:314)
- None
"Service Thread" #9 daemon prio=9 os_prio=0 tid=0x00007fe074219800 nid=0x5665 runnable [0x0000000000000000]
- None
"C1 CompilerThread3" #8 daemon prio=9 os_prio=0 tid=0x00007fe07420e000 nid=0x5664 waiting on condition [0x0000000000000000]
- None
"C2 CompilerThread2" #7 daemon prio=9 os_prio=0 tid=0x00007fe07420c000 nid=0x5663 waiting on condition [0x0000000000000000]
- None
"C2 CompilerThread1" #6 daemon prio=9 os_prio=0 tid=0x00007fe07420a000 nid=0x5662 waiting on condition [0x0000000000000000]
- None
"C2 CompilerThread0" #5 daemon prio=9 os_prio=0 tid=0x00007fe074207000 nid=0x5661 waiting on condition [0x0000000000000000]
- None
"Signal Dispatcher" #4 daemon prio=9 os_prio=0 tid=0x00007fe074205800 nid=0x5660 runnable [0x0000000000000000]
- None
"Finalizer" #3 daemon prio=8 os_prio=0 tid=0x00007fe0741d2800 nid=0x565f in Object.wait() [0x00007fe0486e5000]
java.lang.Thread.State: WAITING (on object monitor)
at java.lang.Object.wait(Native Method)
- waiting on <0x00000000c0034b20> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:143)
- locked <0x00000000c0034b20> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:164)
at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:209)
- None
"Reference Handler" #2 daemon prio=10 os_prio=0 tid=0x00007fe0741ce000 nid=0x565e in Object.wait() [0x00007fe0487e6000]
- waiting on <0x00000000c003bf90> (a java.lang.ref.Reference$Lock)
at java.lang.Object.wait(Object.java:502)
at java.lang.ref.Reference.tryHandlePending(Reference.java:191)
- locked <0x00000000c003bf90> (a java.lang.ref.Reference$Lock)
at java.lang.ref.Reference$ReferenceHandler.run(Reference.java:153)
- None
"main" #1 prio=5 os_prio=0 tid=0x00007fe074008800 nid=0x5654 waiting on condition [0x00007fe07b95f000]
- parking to wait for <0x00000000c02db9c8> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitUninterruptibly(AbstractQueuedSynchronizer.java:1976)
at com.google.common.util.concurrent.Monitor.awaitUninterruptibly(Monitor.java:1102)
at com.google.common.util.concurrent.Monitor.enterWhenUninterruptibly(Monitor.java:473)
at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitStopped(ServiceManager.java:563)
at com.google.common.util.concurrent.ServiceManager.awaitStopped(ServiceManager.java:336)
at org.graylog.collector.services.CollectorServiceManager.awaitStopped(CollectorServiceManager.java:49)
at org.graylog.collector.cli.commands.Run.run(Run.java:73)
at org.graylog.collector.cli.Main.main(Main.java:50)
- None
"VM Thread" os_prio=0 tid=0x00007fe0741c6800 nid=0x565d runnable
"GC task thread#0 (ParallelGC)" os_prio=0 tid=0x00007fe07401e000 nid=0x5655 runnable
"GC task thread#1 (ParallelGC)" os_prio=0 tid=0x00007fe07401f800 nid=0x5656 runnable
"GC task thread#2 (ParallelGC)" os_prio=0 tid=0x00007fe074021800 nid=0x5657 runnable
"GC task thread#3 (ParallelGC)" os_prio=0 tid=0x00007fe074023000 nid=0x5658 runnable
"GC task thread#4 (ParallelGC)" os_prio=0 tid=0x00007fe074025000 nid=0x5659 runnable
"GC task thread#5 (ParallelGC)" os_prio=0 tid=0x00007fe074027000 nid=0x565a runnable
"GC task thread#6 (ParallelGC)" os_prio=0 tid=0x00007fe074028800 nid=0x565b runnable
"GC task thread#7 (ParallelGC)" os_prio=0 tid=0x00007fe07402a800 nid=0x565c runnable
"VM Periodic Task Thread" os_prio=0 tid=0x00007fe07421c000 nid=0x5666 waiting on condition
JNI global references: 359
