eglyn
(Eglyn)
1
Hi all,
I try to configure Graylog to receive Syslog from an idrac console (Dell servers).
I create a Syslog UDP input, on port 5145.
I configure syslog on idrac to ip:5145, but when I send a test message nothing happens
I have a similar config with switchs, and everything works.
I checked Dell documentation, and found nothing special.
Anyone has already test idrac syslog with Graylog ?
Thx
shoothub
(Shoothub)
2
I use iDRAC 9 and graylog UDP input with no problem at all.
- Check if your firewall don’t block connection from iDRAC to graylog box on specified port.
- Also setup correct timezone and NTP setting in iDRAC configuration. It’s mandatory to have time in sync
- Check your graylog’s log, maybe there is and error why graylog don’t process iDRAC message
sudo tail -f /var/log/graylog-server/server.log
