Graylog 7.1 - Try to click on the Menu: System / Cluster Configuration
Following error occurs - (HTML-Site):
The permissions check for the following request failed,
while trying to access /system/cluster.
There was an error fetching a resource: . Additional information: Permission denied when executing command on MongoDB node ‘127.0.0.1:27017’. Please ensure the MongoDB user has the required privileges.
OS Information: Archlinux
Package Version: Graylog 7.1
May 05 20:57:25 vml120 java[110128]: 2026-05-05 20:57:25,122 ERROR: org.graylog2.cluster.nodes.mongodb.MongodbClusterCommand - Permission denied when executing command on MongoDB node '127.0.0.1:27017'. The MongoDB user may lack required privileges.
May 05 20:57:25 vml120 java[110128]: com.mongodb.MongoCommandException: Command execution failed on MongoDB server with error 13 (Unauthorized): 'not authorized on graylog to execute command { profile: -1, $db: "graylog", lsid: { id: UUID("c832845f-3759-4fb7-b56c-61443c3466a6") } }' on server 127.0.0.1:27017. The full response is {"ok": 0.0, "errmsg": "not authorized on graylog to execute command { profile: -1, $db: \"graylog\", lsid: { id: UUID(\"c832845f-3759-4fb7-b56c-61443c3466a6\") } }", "code": 13, "codeName": "Unauthorized"}
Greetings
Klaus.
