please note that I was happy to see the new possibilities with the custom http notfications as I was thinking that this could be easily used to push alerts to abuseipdb.com.
Now I noticed that the API secret is needed in case of an API key but their API is only using the Key and does not use a secret.
I just want to check with you if it makes sense to open a ticket for that.
Hi @TimmiORG
yes, please open a feature request for that. Not something we had expected; but if there is a use case for it, we definitely want to support it.
Did you try passing a dummy secret? The API might just ignore unknown parameters.
do you know how to view the content of the API calls from Graylog?
I only see that the API call is responded with a 401 but I want to make sue the that data I send is looking correct.
