After upgrading from Graylog 5.x to 6.1.5, there has been a degradation in output performance.
OS Information: redhat 8 x64
Package Version: graylog 6.1.5, elasticsearch oss 7.10.2
elasticsearch_connect_timeout = 10s
elasticsearch_socket_timeout = 60s
elasticsearch_max_total_connections = 1024
elasticsearch_max_total_connections_per_route = 16
elasticsearch_max_retries = 2
rotation_strategy = count
retention_strategy = delete
allow_highlighting = false
output_batch_size = 100
output_flush_interval = 1
processbuffer_processors = 128
outputbuffer_processors = 64
outputbuffer_processor_threads_max_pool_size = 64
udp_recvbuffer_sizes = 16777216
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 6
message_journal_dir = /home1/graylog-server/journal
message_journal_max_size = 360gb
message_journal_max_age = 1h
lb_throttle_threshold_percentage = 90
It was a tuning configuration that had been working without issues, and no other changes were made except for the Graylog version upgrade.
We are currently processing an input rate of 1.5 to 2 million per second.
Our setup includes:
- Graylog: 100 physical machines, each with 48 cores.
- Elasticsearch (ES) Pool: A cluster of approximately 200 nodes.
Since our log input is expected to increase further, we need to scale up the output throughput. What would be the best approach to achieve this?
