GrayLog 5.1 blank webpage
Scenario:
  • OS Information: Ubuntu 22.04.2 LTS fresh installation
  • docker v20.10.21
  • docker-compose v1.29.2
  • new GrayLog installation using docker compose
Issue:
the graylog server is reachable via http://[internal_ip_address]:9090 but nothing than a white page
Troubleshootings tried on graylog server:
  • Result of “sudo netstat -lntp”:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:12201           0.0.0.0:*               LISTEN      157153/docker-proxy
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      4871/systemd-resolv
tcp        0      0 127.0.0.1:34599         0.0.0.0:*               LISTEN      17224/containerd
tcp        0      0 0.0.0.0:1514            0.0.0.0:*               LISTEN      157234/docker-proxy
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      16538/sshd: /usr/sb
tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      157212/docker-proxy
tcp6       0      0 :::12201                :::*                    LISTEN      157161/docker-proxy
tcp6       0      0 :::1514                 :::*                    LISTEN      157240/docker-proxy
tcp6       0      0 :::22                   :::*                    LISTEN      16538/sshd: /usr/sb
tcp6       0      0 :::9000                 :::*                    LISTEN      157218/docker-proxy
HTTP/1.1 200 OK
X-UA-Compatible: IE=edge
X-Graylog-Node-ID: c386dafe-88b6-4312-aac1-37a2f0043fe0
X-Frame-Options: DENY
X-Content-Type-Options: nosniff
Content-Security-Policy: default-src 'self'; style-src 'self' 'unsafe-inline'; script-src 'self' 'unsafe-eval'; img-src data: *; connect-src *
Content-Type: text/html
Content-Length: 1593
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="robots" content="noindex, nofollow">
    <meta charset="UTF-8">
    <title>Graylog Web Interface</title>
    <link rel="shortcut icon" href="/assets/favicon.png">
  </head>
  <body>
    <div id="app-root" />
    <script src="/config.js"></script>
    <script src="/assets/vendor.8a712d83b311029bb0b6.js"></script>
    <script src="/assets/polyfill.b953b8f8d9507ea6486e.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.collector.CollectorPlugin/plugin.org.graylog.plugins.collector.CollectorPlugin.3d73be4ad22bcd245615.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.collector.CollectorPlugin/d7f3395e-765.8a1c541b3d33ef082e9b.js"></script>
    <script src="/assets/plugin/org.graylog.integrations.IntegrationsPlugin/plugin.org.graylog.integrations.IntegrationsPlugin.068db92b12f40069e5f6.js"></script>
    <script src="/assets/plugin/org.graylog.integrations.IntegrationsPlugin/06377e61-300.177f754b22f4c5c567e3.js"></script>
    <script src="/assets/plugin/org.graylog.aws.AWSPlugin/plugin.org.graylog.aws.AWSPlugin.b729e45314bd65faaa0f.js"></script>
    <script src="/assets/plugin/org.graylog.aws.AWSPlugin/a09fd9c1-300.e1674da2e4f972ee06e7.js"></script>
    <script src="/assets/app.ec2c9fc60785a65a39e6.js"></script>
    <script src="/assets/804bf16d-924.f70ecb144a779af893b6.js"></script>
    <script src="/assets/804bf16d-4012.9923a21a06a6f13457d9.js"></script>
  </body>
</html>
  • Same result executing "curl -i http://[internal_ip_address]:9000
If I call http://[internal_ip_address]:9000 from an allowed client I can see this error trace:
graylog_1        | 2023-07-11 12:36:56,644 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server up and running.
graylog_1        | 2023-07-11 12:42:18,137 ERROR: org.glassfish.jersey.server.ServerRuntime$Responder - An I/O error has occurred while writing a response message entity to the container output stream.
graylog_1        | org.glassfish.jersey.server.internal.process.MappableException: java.io.IOException: Connection closed
graylog_1        |      at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:67) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:139) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1116) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:642) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:373) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:363) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:258) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684) [graylog.jar:?]
graylog_1        |      at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
graylog_1        |      at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
graylog_1        |      at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
graylog_1        |      at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
graylog_1        |      at java.lang.Thread.run(Unknown Source) [?:?]
graylog_1        | Caused by: java.io.IOException: Connection closed
graylog_1        |      at org.glassfish.grizzly.asyncqueue.TaskQueue.onClose(TaskQueue.java:307) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.onClose(AbstractNIOAsyncQueueWriter.java:477) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOTransport.closeConnection(TCPNIOTransport.java:379) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.NIOConnection.doClose(NIOConnection.java:643) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.NIOConnection$6.run(NIOConnection.java:609) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.DefaultSelectorHandler.execute(DefaultSelectorHandler.java:213) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.NIOConnection.terminate0(NIOConnection.java:603) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOConnection.terminate0(TCPNIOConnection.java:267) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:112) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:82) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.processAsync(AbstractNIOAsyncQueueWriter.java:320) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:84) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:53) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:515) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:89) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.strategies.SameThreadIOStrategy.executeIoEvent(SameThreadIOStrategy.java:79) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.strategies.AbstractIOStrategy.executeIoEvent(AbstractIOStrategy.java:66) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.SelectorRunner.iterateKeyEvents(SelectorRunner.java:391) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.SelectorRunner.iterateKeys(SelectorRunner.java:360) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.SelectorRunner.doSelect(SelectorRunner.java:324) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.SelectorRunner.run(SelectorRunner.java:255) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:569) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:549) ~[graylog.jar:?]
graylog_1        |      ... 1 more
graylog_1        | Caused by: java.io.IOException: Connection reset by peer
graylog_1        |      at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:?]
graylog_1        |      at sun.nio.ch.SocketDispatcher.write(Unknown Source) ~[?:?]
graylog_1        |      at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source) ~[?:?]
graylog_1        |      at sun.nio.ch.IOUtil.write(Unknown Source) ~[?:?]
graylog_1        |      at sun.nio.ch.SocketChannelImpl.write(Unknown Source) ~[?:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOUtils.flushByteBuffer(TCPNIOUtils.java:125) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOUtils.writeCompositeBuffer(TCPNIOUtils.java:64) ~[graylog.jar:?]
graylog_1        |      at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:105) ~[graylog.jar:?]
Below my docker-compose.yml:
  version: '2'
  services:
    mongodb:
      image: mongo:5.0.13
      volumes:
        - mongo_data:/data/db
# Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
    elasticsearch:
      image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
      volumes:
      environment:
        - http.host=0.0.0.0
        - transport.host=localhost
        - network.host=0.0.0.0
      ulimits:
        memlock:
          soft: -1
          hard: -1
      mem_limit: 1g
    graylog:
      image: graylog/graylog:5.1
      volumes:
        - graylog_data:/usr/share/graylog/data
      environment:
        - GRAYLOG_PASSWORD_SECRET=[xxxxxxxxxxxxxxxxxxxxxxxxxxx]
        - GRAYLOG_ROOT_PASSWORD_SHA2=[xxxxxxxxxxxxxxxxxxxxxxxxxxx]
        - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
        - GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
        - GRAYLOG_ELASTICSEARCH_HOSTS=http://elasticsearch:9200
        - GRAYLOG_MONGODB_URI=mongodb://mongodb:27017/graylog
      #entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
      entrypoint: /docker-entrypoint.sh
      links:
        - mongodb:mongo
        - elasticsearch
      restart: always
      depends_on:
        - mongodb
        - elasticsearch
      ports:
        - 9000:9000 # Graylog web interface and REST API
        - 1514:1514 # Syslog TCP
        - 1514:1514/udp # Syslog UDP
        - 12201:12201 # GELF TCP
        - 12201:12201/udp # GELF UDP
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
  volumes:
    mongo_data:
      driver: local
    es_data:
      driver: local
    graylog_data:
      driver: local
Side note: I had to comment out the “entrypoint” line because otherwise that line returned an error: the docker-entrypoint.sh file is missing
Any help is really appreciated!
Thank you
What is your host os (distro, version, etc) and what version of docker are you using?
I’ll test out your compose file and see what i can find.
Thanks,
Drew
Thanks you for your reply!
I reported these info in “Scenario” section:
  • docker v20.10.21
Thank you!
My apologies, i can’t read :upside_down_face:
Testing now.
I was able to take your provided compose file and run it exactly as is (specifying the password secret and root sha2 vars). I tested on both mac os (arm) and ubuntu 22 (x86) and both loaded the compose file and graylog was accessible.
sudo docker compose -f compose.yml --env-file env.txt up
version: '2'
services:
  mongodb:
    image: mongo:5.0.13
    volumes:
  elasticsearch:
    volumes:
    environment:
      - http.host=0.0.0.0
    ulimits:
      memlock:
        soft: -1
        hard: -1
    mem_limit: 1g
  graylog:
    volumes:
    environment:
      - GRAYLOG_PASSWORD_SECRET=${GRAYLOG_PASSWORD_SECRET}
      - GRAYLOG_ROOT_PASSWORD_SHA2=${GRAYLOG_ROOT_PASSWORD_SHA2}
    links:
      - mongodb:mongo
      - elasticsearch
    restart: always
    depends_on:
      - mongodb
      - elasticsearch
    ports:
volumes:
  mongo_data:
    driver: local
  es_data:
    driver: local
  graylog_data:
    driver: local
Can you confirm you are using the correct HTTP port? Should be :9000.
Yes, I can confirm…
The VM ip address is 10.3.5.53, and from another client I’m calling http://10.3.5.53:9000.
Blank page with the error I reported… :frowning:
Side note: using a docker compose file with GrayLog 5.0, I’ve no problem… GrayLog works properly…
Very strange… if I call from my client a remote resource (via browser or via curl), it is returned correctly.
I.e., if I call http://10.3.5.53:9000/config.js the webpage return:
window.appConfig = {
  gl2ServerUrl: '/api/',
  gl2AppPathPrefix: '/',
  rootTimeZone: 'UTC',
  pluginUISettings: { },
  isCloud: false,
  featureFlags: {
  "cloud_inputs" : "on",
  "scripting_api_preview" : "on",
  "search_filter" : "on",
  "preflight_web" : "off"
  telemetry: {
  "host" : "https://telemetry.graylog.cloud",
  "api_key" : "phc_t3lgBB66QsPW4HEfiGopO14um4XGNtBcefEKYWelWda",
  "enabled" : true
but if I call the home page http://10.3.5.53:9000, I receive a blank page and (on GrayLog VM) the error message I posted above.
Any idea? :frowning:
Thank you
Fabrizio
Other updates: same identical issue installing GrayLog 5.1 following this guide: Ubuntu Installation
Last update: forcing the installation of graylog-server v. 5.1.2-1, everything works properly! Now I can access WebUI and use GrayLog.
I think there’s some issue regarding js files in v5.1.3-1.
Thank you!
Very interesting. I’m trying to reproduce but am unable to :frowning:
I’m curious, what web browser/version are you using?
I tested with Microsoft Edge 114.0.1823.79 and Chrome 114.0.5735.199.
The browsers reported me this error:
with the error “Connection closed (200)”.
So probably a js issue?
