Hi, i am struggling to configure automatic discovery for elasticsearch nodes.
On the host there are two docker containers: one of graylog and the second of elasticsearch.
I configure the following in graylog.conf
elasticsearch_hosts = http://***:***@127.0.0.1:9200
elasticsearch_discovery_enabled = True
elasticsearch_discovery_default_user = ****
elasticsearch_discovery_default_password = ****
elasticsearch_discovery_default_scheme = http
elasticsearch_discovery_filter = es-datanode*
elasticsearch_discovery_frequency = 10s
elasticsearch_version = 6
elasticsearch_connect_timeout = 10s
elasticsearch_socket_timeout = 60s
elasticsearch_max_total_connections = 300
After restarting graylog container i observe the following in the logfile
2021-05-16T14:09:15.693Z INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=172.31.201.11:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 6, 21]}, minWireVersion=0, maxWireVersion=6, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1358426, setName='rs01', canonicalAddress=172.31.201.11:27017, hosts=[172.31.200.175:27017], passives=[172.31.201.11:27017, 172.31.201.137:27017], arbiters=[], primary='172.31.200.175:27017', tagSet=TagSet{[]}, electionId=null, setVersion=3, lastWriteDate=Sun May 16 14:09:15 UTC 2021, lastUpdateTimeNanos=2957503880646318}
2021-05-16T14:09:15.759Z INFO [connection] Opened connection [connectionId{localValue:4, serverValue:40454}] to 172.31.200.175:27017
2021-05-16T14:09:15.911Z INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <16384> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2021-05-16T14:09:16.057Z INFO [ElasticsearchVersionProvider] Elasticsearch version set to 6.0.0 - disabling version probe.
2021-05-16T14:09:16.094Z INFO [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2021-05-16T14:09:16.094Z INFO [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2021-05-16T14:09:16.145Z INFO [JestClientFactory] Using custom ObjectMapper instance
2021-05-16T14:09:16.146Z INFO [JestClientFactory] **Node Discovery disabled..**.
2021-05-16T14:09:16.146Z INFO [JestClientFactory] Idle connection reaping disabled...
2021-05-16T14:09:16.146Z INFO [JestClientFactory] Authentication cache set for preemptive authentication
Meaning it does not use node autodiscovery defined by the filter, and using only local elasticsearch container to ingest logs/send search requests
Can you please point me where could be the problem ?
