Graylog 4.0 RC1 - how to view map of geolocation ?
No World Map entry appears like in a older version
Has anyone had the opportunity to test the Geolocation function on this version?
Same problem on Graylog v4.0.0-rc.2+49529be
Did you try creating a new aggregation, choosing World Map as a visualisation type, count as a metric and geolocalisation as a field ?
Thanks for the answer, last night just as you suggested I had solved it, right now I use Graylog version 2.4.6 and version 4 has a completely changed user interface compared to the old version
Thanks again for the answer
I think later you will find that 4 lacks a lots of useful features.
In this case 3.1.4 is what you need
