I’m using Graylog 2.5 Collector sidecar (v.0.1.8) on Windows Environment.
I don’t understand how sidercar is abled to connect to graylog via ReST; does it require a token authentication?
Looking in the sidecar log I see
time=“2020-12-11T01:06:55+01:00” level=error msg="[RequestConfiguration] Fetching configuration failed: Get http://xxx.xxx.xxx.xxx:9000/api/plugins/org.graylog.plugins.collector/6dc068df-f77e-441a-86f8-ae3c0419be4e?tags=[“TAG01”]: dial tcp xxx.xxx.xxx.xxx:30090: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
I have the same message for PUT and msg="[UpdateRegistration] Failed to report collector status to server:
Can somebody help me to understand the strange behavior?
How does it works?
Gianluca
