Hello Everyone,
I want to pull AWS CloudFront logs directly to the Graylog. Is it possible? If yes, What is the best way to fetch the logs?
Currently, I’m using Graylog Version: 3.3.2
Hello Everyone,
Nearly the first hit with a simple google search - here. You didn’t give much to go on so I don’t know if it will help.
