hi,
I updated the Maxmind database (City Lite). It seems, that after that the GeoIP plugin throws exceptions when encountering internal (10.x.x.x) addresses:
2017-03-14T10:32:13.176+00:00 WARN [ProcessBuffer] Unable to process event MessageEvent{raw=null, message=null, messages=null}, sequence 144912204
java.lang.InternalError: a fault occurred in a recent unsafe memory access operation in compiled Java code
at com.maxmind.db.Decoder$Type.get(Decoder.java:52) ~[?:?]
at com.maxmind.db.Decoder.decode(Decoder.java:128) ~[?:?]
at com.maxmind.db.Decoder.decode(Decoder.java:87) ~[?:?]
at com.maxmind.db.Reader.resolveDataPointer(Reader.java:252) ~[?:?]
at com.maxmind.db.Reader.get(Reader.java:150) ~[?:?]
at com.maxmind.geoip2.DatabaseReader.get(DatabaseReader.java:151) ~[?:?]
at com.maxmind.geoip2.DatabaseReader.city(DatabaseReader.java:202) ~[?:?]
at org.graylog.plugins.map.geoip.GeoIpResolverEngine.extractGeoLocationInformation(GeoIpResolverEngine.java:106) ~[?:?]
at org.graylog.plugins.map.geoip.GeoIpResolverEngine.filter(GeoIpResolverEngine.java:79) ~[?:?]
at org.graylog.plugins.map.geoip.processor.GeoIpProcessor.process(GeoIpProcessor.java:79) ~[?:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.handleMessage(ProcessBufferProcessor.java:119) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.dispatchMessage(ProcessBufferProcessor.java:105) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:82) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:45) ~[graylog.jar:?]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_121]
