Hi all, I’m using graylog free version 7.0.2. I’ve configured an output in GELF - TCP with this configuration:
connect_timeout:
1000
hostname:
192.168.XXX.XXX
max_inflight_sends:
512
port:
12201
protocol:
TCP
queue_size:
512
reconnect_delay:
500
tcp_keep_alive:
false
tcp_no_delay:
false
tls_trust_cert_chain:
tls_verification_enabled:
false
and we forward on it the default stream.
The server that should receive the output is listening but seems that graylog doesn’t send the payload in the output.
What can I have done wrong?
Thanks in advance.
