Gelf in DHCP not showing messages
I’ve installed nxlog on a Windows server hosting a DHCP service.
I’m interested in viewing logs of DHCP events on Graylog.
I have set up the following config in nxlog:
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
LogFile %ROOT%\data\nxlog.log
Loglevel debug
Module xm_gelf Module im_file File "C:\Windows\Sysnative\dhcp\DhcpSrvLog-*.log" PollInterval 1 SavePos True ReadFromLast True Recursive False RenameCheck True Exec $FileName = file_name(); # Send file name with each message Module om_udp Module om_udp Host 192.168.205.242 Port 12201 OutputType GELF Exec $short_message = $raw_event; # Avoids truncation of the short_message field. Exec $gl2_source_collector = '5b4c8c06636311037456fe97'; Exec $Hostname = hostname_fqdn(); Path DHCP_IN => DHCP_OUT
I have added a GELF UDP input. I can see the network counters go up but no messages show.
Can you please help me?
The only thing I managed to find is indexing errors of the following:
{“type”:“mapper_parsing_exception”,“reason”:“failed to parse”,“caused_by”:{“type”:“illegal_argument_exception”,“reason”:“Can’t parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]”}}=
Please format your post properly, so that line breaks are visible:
https://community.graylog.org/faq#format-markdown
Also, please post the complete logs of your Graylog node. What you’ve posted is usually just a warning when using Elasticsearch 5.x.
Thank you for your patience. Apologize for the clutter.
Here’s a more detailed post:
I am using Graylog 2.4.5.
I have a DHCP service installed on Windows Server 2012R2.
I’m intrested in seeing DHCP events on Graylog.
What I’ve done:
Installed nxlog with the following configuration:
Loglevel debug
<Extension gelf>
    Module xm_gelf
</Extension>
<Input 578f9dbc0ae2f10b1139b6a9>
    Module im_file
    PollInterval 1
    SavePos	True
    ReadFromLast True
    Recursive False
    RenameCheck True
</Input>
<Output 578f97f40ae2f10b1139b093>
    Module om_udp
    Host 192.168.......
    Port ....
    OutputType  GELF
</Output>
I’ve installed the DHCP content pack from the Market.
Can you please intruct me on how to get the logs? Sorry for asking a trivial question.
Check http://docs.graylog.org/en/2.4/pages/configuration/file_location.html for the location of the log files in your particular installation of Graylog.
This was in Your first post, a snippet from route section, I believe. Are You sure this is OK? Where are DHCP_IN and DHCP_OUT module names defined?
Please disregard the first post, this was a template I have found.
My 2nd post shows current config.
I do need to spend more time on reading how this works exactly.
2018-07-17_09:17:44.92143 WARN  [Messages] Failed to index message: index=<graylog_0> id=<438ecf21-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:17:44.92145 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:17:48.92137 WARN  [Messages] Failed to index message: index=<graylog_0> id=<45ec6e31-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:17:48.92138 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:17:50.92129 WARN  [Messages] Failed to index message: index=<graylog_0> id=<471d9b30-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:17:50.92131 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:03.92156 WARN  [Messages] Failed to index message: index=<graylog_0> id=<4edddbf0-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:03.92163 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:07.92266 WARN  [Messages] Failed to index message: index=<graylog_0> id=<514035f1-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:07.92269 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:09.92146 WARN  [Messages] Failed to index message: index=<graylog_0> id=<527162f0-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:09.92152 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:22.92261 WARN  [Messages] Failed to index message: index=<graylog_0> id=<5a37e540-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:22.92265 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:26.92270 WARN  [Messages] Failed to index message: index=<graylog_0> id=<5c958450-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:26.92271 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:28.92152 WARN  [Messages] Failed to index message: index=<graylog_0> id=<5dc6b150-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:28.92158 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:34.92327 WARN  [Messages] Failed to index message: index=<graylog_0> id=<615a3851-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:34.92333 WARN  [Messages] Failed to index message: index=<graylog_0> id=<615a8672-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:34.92336 WARN  [Messages] Failed to index message: index=<graylog_0> id=<615aad80-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:34.92339 ERROR [Messages] Failed to index [3] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:43.92134 WARN  [Messages] Failed to index message: index=<graylog_0> id=<66b7f801-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:43.92136 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:47.92252 WARN  [Messages] Failed to index message: index=<graylog_0> id=<691a7910-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:47.92258 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:49.92246 WARN  [Messages] Failed to index message: index=<graylog_0> id=<6a4b7f03-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:49.92248 WARN  [Messages] Failed to index message: index=<graylog_0> id=<6a4b7f02-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:49.92250 ERROR [Messages] Failed to index [2] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:18:58.92254 WARN  [Messages] Failed to index message: index=<graylog_0> id=<6faaec61-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:18:58.92256 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:19:02.92268 WARN  [Messages] Failed to index message: index=<graylog_0> id=<720afc70-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:19:02.92276 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:19:06.92125 WARN  [Messages] Failed to index message: index=<graylog_0> id=<746d5671-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:19:06.92126 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:19:08.92136 WARN  [Messages] Failed to index message: index=<graylog_0> id=<759e8370-89a2-11e8-b6ea-005056a91822> error=<{"type":"mapper_parsing_exception","reason":"failed to parse","caused_by":{"type":"illegal_argument_exception","reason":"Can't parse [index] value [not_analyzed] for field [SourceModuleType], expected [true] or [false]"}}>
2018-07-17_09:19:08.92137 ERROR [Messages] Failed to index [1] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.
2018-07-17_09:19:19.31467 INFO  [DashboardWidgetsResource] Updated widget <9655e13d-4c45-488e-9367-bd9f5497a0a6> on dashboard <5b4c8c06636311037456feac>. Reason: REST request.
Ok
There is an example how to collect DHCP events using nxlog
Thanks. This is weird. I see the counters going up. Meaning messages are received but I can’t see any in Graylog.
Try rotating the active write index (System / Indices / Index Set / Maintenance).
http://docs.graylog.org/en/2.4/pages/configuration/index_model.html
Brilliant!!!
Works!
Now I have to learn how to better parse the messages but I will work on that.
You saved me. :]
One quick question though - Once enabled, I get a warning:
Elasticsearch cluster is yellow. Shards: 8 active, 0 initializing, 0 relocating, 4 unassigned
Is there any way I can solve this quickly?
How many Elasticsearch nodes are you running?
If you’re only running a single Elasticsearch node, you have to disable shard replicas.
http://docs.graylog.org/en/2.4/pages/configuration/index_model.html#index-set-configuration
I only have one node. Can I disable by changing the following (from 4) in the graylog.conf file?
elasticsearch_shards = 0
No. Read the documentation section I’ve linked to.
Thank you. Now it’s all green.
