GELF HTTP send address
Hello, New to Graylog :slight_smile: :slight_smile:
Trying to send GELF HTTP using CURL over port 5555.
Set up:
Graylog server is installed on 10.0.0.237:9000
Local machine (source of message): 10.0.0.85.
Tried creating an input but it wont accept port 9000 so I changed it to port 5555.
Documentation says to use http://graylog/example.org:[port number]/gelf.
I am not sure where to get the url (other than the destination ip address) and I cant send over port 9000. Any help is appreciated.
Thanks…
You probably misunderstand how to create proper Input:
  1. Every Input should use it’s own port
  2. Don’t try to use port 9000 for input, as it’s a port, where listen graylog web interface
  3. GELF HTTP Input need own port, by default it is 12201
  4. Proper URL for GELF HTTP is http://graylog.example.com:PORT/gelf or you can also use IP http://10.0.0.237:PORT/gelf
  5. Check that your firewall don’t block your PORT used in GELF HTTP Input from local machine to graylog server
I think, documentation is clear, how to use curl:
https://docs.graylog.org/en/3.2/pages/gelf.html#sending-gelf-messages-via-http-using-curl
Thanks!
I tried the sending messages using curl as said in the instructions and I get the following:
I then checked the status of elastic search and got the following:
Any help?
Your Elastic Search database crashed, so check elastic log file to find the reason. Due to crashed elastic db, graylog couldn’t show anything and return error 500.
when I opened the log file using nano, here is what I found. I am new to this so dont really wanna mess up anything. Any ideas on the best way to fix this?
I just scrolled down to the very end of the file.
thanks.
I also gathered from one of the forums that the JAVA_HOME path might not be set correctly. When I try to access the configuration file at etc/default/elasticsearch , I get a “Permission Denied” error.
Not sure how to go about it…
@judel5
How did you install Graylog on your device?
Could you give us a little more info about your environment?
Hi @judel5,
did use follow official documentation to install Elastic Search? Because I see in your log file that x-pack modules were loaded, which can cause problems with graylog. Graylog recommend to install OSS version of elastic search packages (elasticsearch-oss) without x-pack extentions:
https://docs.graylog.org/en/3.2/pages/installation/os/ubuntu.html#elasticsearch
Check your installed version:
dpkg -l |grep -i elastic
The device is a dell desktop with intel core i5. I believe it is about 250GB and 4GB ram. The OS is Ubuntu 19.04.
Thanks. So at this point does it make sense to reinstall or is there a fix that I can apply? I’lll check the exact version when I get home later today.
Thanks,
Jude
