robp1234
(Robp1234)
August 27, 2019, 11:59am
1
Just built a brand new 3.1 Graylog instance, and in the process of migrating over. I don’t seem to have any pre-configured lookup tables in this version:
vs this in our 2.5.1 install:
I was setting up TOR node and Threat Intel lookups. Have I broken something, or do these need to be set up from scratch in 3.1?
thanks
Rob
jan
(Jan Doberstein)
August 27, 2019, 12:35pm
2
we decided not install the lookup tables by default.
So you can install them in System > Content packs and select the pre defined you want to have …
We decided to not overload the system already with lookup tables the user might never use.
