I have a linux server and i forward the system logs to a graylog server.
But i have a log from a backup process created in /tmp/backup.log.
How can i forward this logfile to graylog ?
Thanks for your help,
Matt
Matt
I have follow this article [DBMentors - Inam Bukhari's Blog: Configure Rsyslog with Any Log File] and now my logfile is send to graylog and i see the trace.
But how can i say to rsyslog to take the first column of the trace file to get the time date ?
Here line of trace file :
2022/10/13-14:46:17 database sauvegarde: debut_script: debut - lancement script de sauvegarde
2022/10/13-14:46:17 database sauvegarde: arguments: database name : DATABASE
2022/10/13-14:46:17 database sauvegarde: arguments: catalogue RMAN: RMAN
2022/10/13-14:46:17 database sauvegarde: arguments: backup type : level_0
2022/10/13-14:46:17 database sauvegarde: arguments: purge ArchiveLog : 0
Matt
Hello @mcoussi
I had to do this a couple times. Most, if not all log shippers place a bit on log file so it knows where the knew logs start. Iβm not sure if beat shippers can do this but when I test configuration from forum this is how i upload those files.
In Nxlog you create a INPUT
<Input old_log_file>
Module im_file
File "C:\some\path\to\old\file\greg_labtop.log"
SavePos TRUE //This saves the Posistion after NXLog restarts or starts. Set to FALSE to scan all of the Log file. When done sending set it back if need be.
ReadFromLast TRUE //If ReadFromLast is FALSE, the module will read all logs from the file. .
PollInterval 1
</Input>
Donβt forget to set the Output and Route.
<Route >
Path old_log_file=> out
</Route>
When you execute
root # systemctl restart nxlog
It will grab all the logs on that file/s.
Example I used your logs from above.
As for
Perhaps the Timestamp in the picture above is what you want?
I have resolved my problem with the logger command in my backup script to write in local syslog of server and forward it to Graylog.
logger -t mysql-${OPE_DB_NAME,,}-backup "${OPE_FONCTION^h}: ${OPE_STDOUT}"
Thanks for your time and your help,
Matt
