Flowgger is a fast, simple and lightweight log collector
@jedisct1
View on Github
Open Issues
Stargazers
Flowgger is a fast, simple and lightweight data collector written in Rust.
It reads log entries over a given protocol, extracts them, decodes them using a given format, re-encodes them into a different format, and asynchronously pushes the result into a remote data store.
Flowgger is designed to be:
- Paranoid: it carefully validates input data to prevent injection of malformed/incomplete records down the chain.
- Safe: written in Rust, without any
unsafecode. - Fast: even though messages are systematically parsed and validated, Flowgger is orders of magnitude faster than Logstash and Fluentd.
- Standalone: it comes as a single executable file, and doesn’t require a JVM.
Flowgger supports common input types: stdin, UDP, TCP, TLS and Redis, as well as multiple input formats: JSON (GELF), LTSV, Cap’n Proto and RFC5424. Normalized messages can be sent to Kafka, Graylog, to downstream Flowgger servers, or to other log collectors for further processing.
