Filebeat via sidecar: Do I need logstash?
Hi All,
I am trying to send /var/log/*.log from the same machine on which my graylog is installed. I configured a sidecar with filebeat and was trying to use the default configuration. However, it tries to send the output to logstash, and I don’t have logstash installed. If I understand correctly, graylog should be able to digest the logs itself…
So what do I have to write in the configuration, instead of:
output.logstash:
hosts: [“192.168.1.1:5044”]
Many thanks,
Oren
OK I figured that out. I have to setup a beat input in Graylog and define it as a logstash output host…
