Filebeat shipped logs appeared in graylog web interface delayed by 1 hour
Graylog 3
elasticsearch 5.6.16
filebeat 5.6.16
i need to know why shpped logs delayed by 1 hour :
Filebeat configuration on remote server:
###################### Filebeat Configuration Example #########################
# This file is an example configuration file highlighting only the most common
# options. The filebeat.full.yml file from the same directory contains all the
# supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/filebeat/index.html
#=========================== Filebeat prospectors =============================
filebeat.prospectors:
# Each - is a prospector. Most options can be set at the prospector level, so
# you can use different prospectors for various configurations.
# Below are the prospector specific configurations.
- input_type: log
  # Paths that should be crawled and fetched. Glob based paths.
  paths:
    #- /var/log/*.log
     - /home/dwh/GrayLog/log/*.log
     - /home/tibuser/DeploymentPackages/OMS-I/log/oms.log
    #- c:\programdata\elasticsearch\logs\*
  # Exclude lines. A list of regular expressions to match. It drops the lines that are
  # matching any regular expression from the list.
  #exclude_lines: ["^DBG"]
  # Include lines. A list of regular expressions to match. It exports the lines that are
  #include_lines: ["^ERR", "^WARN"]
  # Exclude files. A list of regular expressions to match. Filebeat drops the files that
  # are matching any regular expression from the list. By default, no files are dropped.
  #exclude_files: [".gz$"]
  # Optional additional fields. These field can be freely picked
  # to add additional information to the crawled log files for filtering
  #fields:
  #  level: debug
  #  review: 1
  ### Multiline options
  # Mutiline can be used for log messages spanning multiple lines. This is common
  # for Java Stack Traces or C-Line Continuation
  # The regexp Pattern that has to be matched. The example pattern matches all lines starting with [
  #multiline.pattern: ^\[
  #multiline.pattern: ^\</
  # Defines if the pattern set under pattern should be negated or not. Default is false.
  #multiline.negate: false
  # Match can be set to "after" or "before". It is used to define if lines should be append to a pattern
  # that was (not) matched before or after or as long as a pattern is not matched based on negate.
  # Note: After is the equivalent to previous and before is the equivalent to to next in Logstash
  #multiline.match: after
#================================ General =====================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
#tags: ["service-X", "web-tier"]
# Optional fields that you can specify to add additional information to the
# output.
#fields:
#  env: staging
#================================ Outputs =====================================
# Configure what outputs to use when sending the data collected by the beat.
# Multiple outputs may be used.
#dashboards.enabled: true
#-------------------------- Elasticsearch output ------------------------------
#output.elasticsearch:
  # Array of hosts to connect to.
  #hosts: ["localhost:9200"]
  # Optional protocol and basic auth credentials.
  #protocol: "https"
  #username: "elastic"
  #password: "changeme"
#----------------------------- Logstash output --------------------------------
output.logstash:
  # The Logstash hosts
  hosts: "10.208.221.18:5044"
  # Optional SSL. By default is off.
  # List of root certificates for HTTPS server verifications
  #ssl.certificate_authorities: ["/etc/pki/root/ca.pem"]
  # Certificate for SSL client authentication
  #ssl.certificate: "/etc/pki/client/cert.pem"
  # Client Certificate Key
  #ssl.key: "/etc/pki/client/cert.key"
#================================ Logging =====================================
# Sets log level. The default log level is info.
# Available log levels are: critical, error, warning, info, debug
#logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are "beat",
# "publish", "service".
#logging.selectors: ["*"]
Move your time search into the future hour and see if the logs are coming in live, but with the timestamp adjusted for yourself.
I’m going to straight-up assume they are coming in, but being adjusted for your Graylog Web UI of UTC-1. Maybe +1 - I can’t do relative time math at the moment.
Either way - check if the logs are actually coming in live with the wrong timestamp. Then adjust either your profile or the sending device to their correct times. Last resort - modify them with a pipeline rule.
