Filebeat refused by target machine
In fact i have config the BEAT INPUT and in collector i have alredy config the Configure Beats Outputs and Configure Beats inputs.
And when I run the “Graylog-collector-sidecar.exe” it seem nothing wrong
time="2017-11-23T17:31:19+08:00" level=info msg="Starting signal distributor"
time="2017-11-23T17:31:19+08:00" level=info msg="[filebeat] Starting (exec driver)"
time="2017-11-23T17:31:29+08:00" level=info msg="[filebeat] Configuration change detected, rewriting configuration file."
time="2017-11-23T17:31:30+08:00" level=info msg="[filebeat] Stopping"
time="2017-11-23T17:31:33+08:00" level=info msg="[filebeat] Starting (exec driver)"
However i didn’t get any message, so i check out the logs of Filebeat, and i find connect was refused
2017-11-23T17:31:34+08:00 INFO Home path: [C:\Program Files\graylog\collector-sidecar] Config path: [C:\Program Files\graylog\collector-sidecar] Data path: [C:\Program Files\graylog\collector-sidecar\cache\filebeat\data] Logs path: [C:\Program Files\graylog\collector-sidecar\logs]
2017-11-23T17:31:34+08:00 INFO Setup Beat: filebeat; Version: 5.5.1
2017-11-23T17:31:34+08:00 INFO Max Retries set to: 3
2017-11-23T17:31:34+08:00 INFO Activated logstash as output plugin.
2017-11-23T17:31:34+08:00 INFO Publisher name: PC-DUYUCONG
2017-11-23T17:31:34+08:00 INFO Flush Interval set to: 1s
2017-11-23T17:31:34+08:00 INFO Max Bulk Size set to: 2048
2017-11-23T17:31:34+08:00 ERR Not loading modules. Module directory not found: C:\Program Files\graylog\collector-sidecar\module
2017-11-23T17:31:34+08:00 INFO filebeat start running.
2017-11-23T17:31:34+08:00 INFO Registry file set to: C:\Program Files\graylog\collector-sidecar\cache\filebeat\data\registry
2017-11-23T17:31:34+08:00 INFO Loading registrar data from C:\Program Files\graylog\collector-sidecar\cache\filebeat\data\registry
2017-11-23T17:31:34+08:00 INFO States Loaded from registrar: 4
2017-11-23T17:31:34+08:00 INFO Loading Prospectors: 1
2017-11-23T17:31:34+08:00 INFO Start sending events to output
2017-11-23T17:31:34+08:00 INFO Starting Registrar
2017-11-23T17:31:34+08:00 INFO Starting spooler: spool_size: 2048; idle_timeout: 5s
2017-11-23T17:31:34+08:00 INFO Prospector with previous states loaded: 4
2017-11-23T17:31:34+08:00 INFO Starting prospector of type: log; id: 11968943014683501787
2017-11-23T17:31:34+08:00 INFO Loading and starting Prospectors completed. Enabled prospectors: 1
2017-11-23T17:31:44+08:00 INFO Harvester started for file: D:\Program Files (x86)\iVMS8600-TOCC\log\cms\info.log
2017-11-23T17:31:44+08:00 INFO Harvester started for file: D:\Program Files (x86)\iVMS8600-TOCC\log\cms\debug.log
2017-11-23T17:31:44+08:00 INFO Harvester started for file: D:\Program Files (x86)\iVMS8600-TOCC\log\cms\error.log
2017-11-23T17:31:46+08:00 ERR Connecting error publishing events (retrying): dial tcp [::1]:5044: connectex: No connection could be made because the target machine actively refused it.
2017-11-23T17:31:49+08:00 ERR Connecting error publishing events (retrying): dial tcp 127.0.0.1:5044: connectex: No connection could be made because the target machine actively refused it.
2017-11-23T17:31:53+08:00 ERR Connecting error publishing events (retrying): dial tcp [::1]:5044: connectex: No connection could be made because the target machine actively refused it.
2017-11-23T17:31:59+08:00 ERR Connecting error publishing events (retrying): dial tcp 127.0.0.1:5044: connectex: No connection could be made because the target machine actively refused it.
So what could lead to this and how could to resolved it.
Can you see what the Logstash Output section in your filebeat look like?
Is it having a FQDN?
Is the port allowed on the firewall?
You mean collector-sidecar’s output? where i could find it. In fact
I did’t set any model, is this have some infurence
I have closed firewall,and i have configed FQDN in collector_sidecar.yml,but i still refursed by machine
You should have a filebeat config file in C:\Program Files\graylog\collector-sidecar\generated folder
Check how does the logstash output look this.
That IP:Port destination should be reachable from your client where Collector sidecar is running.
Thanks i find where i misconf. In the Configure Beats Outputs-Hosts i conf
['localhost:5044']
But i should use FQDN in there
Thanks, you help me a lot !!!
Ensure that you don’t modify that file.
Instead modify the Beats Output section in your Collector Configuration in UI
