Graylog-server logs :
"Incorrect HTTP method for uri [/graylog_*/_aliases] and method [GET], allowed: [PUT]"
at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:95) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:57) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:62) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.getIndexNamesAndAliases(Indices.java:308) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.getNewestIndexNumber(MongoIndexSet.java:151) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.getNewestIndex(MongoIndexSet.java:146) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.setUp(MongoIndexSet.java:252) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.checkAndRepair(IndexRotationThread.java:138) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:76) ~[graylog.jar:?]
at java.lang.Iterable.forEach(Iterable.java:75) [?:1.8.0_171]
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:73) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_171]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_171]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_171]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_171]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_171]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_171]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_171]
2018-06-18T09:37:07.479+02:00 INFO [MongoIndexSet] Did not find a deflector alias. Setting one up now.
2018-06-18T09:37:07.479+02:00 ERROR [IndexRotationThread] Couldn't point deflector to a new index
org.graylog2.indexer.ElasticsearchException: Couldn't collect aliases for index pattern graylog_*
