Fighting the square brackets, need help with regex
Hi All,
I need to create a pipeline rule to extract the name of the component from my Mule-based application. This name I then store in a separate field.
Done this many times using simple regex, but the square brackets are causing me headaches.
Example (where I want sphinx-wh-system-api to be extracted)
DEBUG 2024-08-02 13:22:24,053 [[MuleRuntime].uber.1869: [sphinx-wh-system-api].whab-sphinx-main. BLOCKING @1f5b57f5] [processor: whab-sphinx-main/processors/0; event: 1-1153fe20-692f-11ef-b11a-0050569ea35d] org.mule.db.commons.shaded.internal.StatementStreamingResultSetCloser: Closing 1 resultSets
Any tips appreciated
Hello @invert123
You would need to escape the brackets, this should give you some idea.
\[(sphinx-wh-system-api)\]
Within Graylog you will need to double escape these kinds of special characters, as below.
\\[(sphinx-wh-system-api)\\]
Hopefully this gets you some of the way to an answer.
