This week I rolled out Graylog on a Debian9 box and got it running and ingesting some syslogs from some of our linux servers. I created a dashboard with 4 different items and tried to set it up as a daily scheduled report and it failed. So I went looking at logs and find this happening about every 5 seconds:
2019-10-04T13:48:21.844-04:00 ERROR [EventProcessorExecutionJob] Event processor <aggregation-v1/5d94ded762c4723dee21af45> failed to execute: Search type returned error:
Fielddata is disabled on text fields by default. Set fielddata=true on [message] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead.Fielddata is disabled on text fields by default. Set fielddata=true on [message] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead. (retry in 5000 ms)
org.graylog.events.processor.EventProcessorException: Search type returned error:Fielddata is disabled on text fields by default. Set fielddata=true on [message] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead.Fielddata is disabled on text fields by default. Set fielddata=true on [message] in order to load fielddata in memory by uninverting the inverted index. Note that this can however use significant memory. Alternatively use a keyword field instead.
at org.graylog.events.processor.aggregation.PivotAggregationSearch.doSearch(PivotAggregationSearch.java:132) ~[graylog.jar:?]
at org.graylog.events.processor.aggregation.AggregationEventProcessor.aggregatedSearch(AggregationEventProcessor.java:199) ~[graylog.jar:?]
at org.graylog.events.processor.aggregation.AggregationEventProcessor.createEvents(AggregationEventProcessor.java:113) ~[graylog.jar:?]
at org.graylog.events.processor.EventProcessorEngine.execute(EventProcessorEngine.java:92) ~[graylog.jar:?]
at org.graylog.events.processor.EventProcessorExecutionJob.execute(EventProcessorExecutionJob.java:111) ~[graylog.jar:?]
at org.graylog.scheduler.JobExecutionEngine.executeJob(JobExecutionEngine.java:166) ~[graylog.jar:?]
at org.graylog.scheduler.JobExecutionEngine.lambda$handleTrigger$2(JobExecutionEngine.java:144) ~[graylog.jar:?]
at com.codahale.metrics.Timer.time(Timer.java:137) ~[graylog.jar:?]
at org.graylog.scheduler.JobExecutionEngine.handleTrigger(JobExecutionEngine.java:144) ~[graylog.jar:?]
at org.graylog.scheduler.JobExecutionEngine.lambda$execute$0(JobExecutionEngine.java:119) ~[graylog.jar:?]
at org.graylog.scheduler.worker.JobWorkerPool.lambda$execute$0(JobWorkerPool.java:110) ~[graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
I have removed all my saved searches and dashboards, and it is still happening.
The only thing I can think of that may have caused this - based on the error - is I tried at one point asking Graylog to start analyzing the message text field - but that caused UI errors so I re-enabled it.
(in System/Configurations/Search Configuration)
So at this point I’m a bit lost. All the stuff I can find with google is how to create custom indexes in elastisearch (which is way over my head.
