Hi everyone,
I crate an extractors and i see on exctractor preview everything ok.
But i see on extractor details “0 hits, 0 misses”.
What’s wrong in this case.
Sorry for this probably so basic or stupidly question but i’m a beginner on graylog.
you should try to hit the full line and not only what you want to get.
It might be an issue, but I would always try to fit the complete line, starting with ^
thank for answer jan.
i tried ^,$ and lot of combination but I couldn’t.
i just wanna take skip frame count on “09.05.2019 12:15:51.631 (7164) PERF: RtpOutput – skip 2 frame”
the visual test on regex101 uses not JAVA Regex like you can test on
https://www.freeformatter.com/java-regex-tester.html
as example.
