Extractors and High CPU/Process Buffers
Is there a metric to monitor to determine ,which extractor or set or extractors is causing the most impact on the process buffer pool?
I would also like to know if this is possible
Hi @Bashere1
When you are in the “Extractors for XXXX input” you can click on “Details” for each extractor. There, you can see the Metrics (statistics) for that particular extractor. That way you should have an idea about how it is behaving
Hope this helps !
