Extract logs from a json array
Hello.
-Describe your incident:
I am trying to process the following message, in it there is an array of json with different logs:
POST /gelf HTTP/1.1
Authorization: Basic YTphYWFhYWE=
Content-Type: application/json; charset=utf-8
Content-Length: 479
Host: 192.168.0.233:12201
Connection: Keep-Alive
Accept-Encoding: gzip
User-Agent: okhttp/4.9.2
      "app_version":"1.0.2",
      "level":12,
      "short_message":"DEBUG",
      "message":"Test log message 1 ",
      "level":12,
      "message":"Test log message 2 ",
I have a GELF HTTP input and it doesn’t receive anything, if I send the same message but without the json array (without being inside “[ ]”) if it reaches the GELF HTTP input, it shows me the first element of the array.
  • Describe your environment:
    OS Information: Debian 8
Package Version:
mongodb-org-server v3.6.23
elasticsearch v2.4.6
Graylog v2.2.3
  • How can the community help?
How can I see all the elements of the json array?
Hello && Welcome
I had to fix your posts is was very hard to read, please us the markup when posting logs and configuration. For a better understanding please look here
Did you check your logs on both the remote device and Graylog?
By chance have you execute tcpdump on your Graylog server?
Hello, with this input:
If I send a json structure with array format [{...}, {...}, {...}]
curl -H "Connection: Keep-Alive" -sH 'Accept-encoding: gzip' -X POST -H 'Content-Type: application/json' -d '[{"app_version":"1.0.2","level":7,"short_message":"DEBUG","full_message":"Test message 1 \n"},{"app_version":"1.0.2","level":7,"short_message":"DEBUG","full_message":"Test message 2 \n"}]' 'http://192.168.0.233:5555/gelf'
And I look at “Show received messages” I see that there is nothing
If I send a raw json structure of array {...}, {...}, {..}
curl -H "Connection: Keep-Alive" -sH 'Accept-encoding: gzip' -X POST -H 'Content-Type: application/json' -d '{"app_version":"1.0.2","level":7,"short_message":"DEBUG","full_message":"Test message 1 \n"},{"app_version":"1.0.2","level":7,"short_message":"DEBUG","full_message":"Test message 3 \n"}' 'http://192.168.0.233:5555/gelf'
And I look at “Show received messages” I see the message
If I look at “journal/messagejournal” I see that both were received by Graylog server.
How could I config one input to receive json with structure [{..}, {…}] ?
This might be from the type of input your using. I noticed your running a old version of graylog so I’m not sure if you have this input shown below.
Maybe try that see is that works.
