Exclude IPv6 addresses in pipeline rule?
I recently set up an integration to GreyNoise Community and it is working swimmingly, except I get occasional errors in my Graylog log:
WARN  [GreyNoiseCommunityIpLookupAdapter] '::1' is an IPv6 Address.  'GreyNoise Community IP Lookup' does not support IPv6 Addresses
I would like to filter the IPv6 addresses within the pipeline rule calling the lookup so that they are not sent to GreyNoise.
  • OS Information: Ubuntu 22.04
  • Package Version: 5.0.3+a82acb2
I added the below to my pipeline rule, but I have a low confidence that I am using the function correctly. Hoping someone can spot an error or make a suggestion on another way to avoid running the rule action on IPv6 addresses.
Here’s the when block:
    has_field("SrcIP") &&
    is_ip(to_ip($message.SrcIP)) &&
    !grok_exists("%{IPV6:$message.SrcIP}") &&
    !in_private_net(to_string($message.SrcIP)) &&
    !cidr_match("169.254.0.0/16",to_ip($message.SrcIP))
The !grok_exists("%{IPV6:$message.SrcIP}") && is intended to stop processing if there is an IPv6 address in the SrcIP field, but it is not working.
Provide advice on getting the pipeline rule to stop processing in the event of an IPv6 address.
Hey @faen
Not quite sure if this will work for ya. Here are couple examples:
rule "proxy  address"
When
 cidr_match("91.0.0.0/8", to_ip("91.184.102.100")) &&
  ! cidr_match("92.0.0.0/8", to_ip("91.184.102.100"))
   set_field("proxy_address", "91.184.102.100");
And/Or something like this?
rule "from datacenter subnet"
    cidr_match("192.168.1.0/24", to_ip($message.gl2_remote_ip)) OR cidr_match("192.168.2.0/24", to_ip($message.gl2_remote_ip))
    set_field("new_field",);
Or perhap use regex_replace();
Example:
rule "IPv6 "
  has_field("message")
  let anonym_ip = regex_replace(
    pattern: "([0-9A-Fa-f]{1,4}):([0-9A-Fa-f]{1,4}):([0-9A-Fa-f]{1,4}):([0-9A-Fa-f]{1,4}):([0-9A-Fa-f]{1,4}):([0-9A-Fa-f]{1,4}):([0-9A-Fa-f]{1,4}):([0-9A-Fa-f]{1,4}|:)",
    replacement: "$1:$2:yyy:yyy:yyy:yyy:yyy::"
  set_field("message", anonym_ip);
Sorry for the late reply here @gsmith, I’ve had a pretty busy week with other things.
I think your 3rd example might be close to what I am looking for. I might add a rule to make a flag for IPv6 addresses that can be used to exclude those messages from data enrichment that does not support IPv6. I’ll post an update when I have time to get it running.
